Hey gang... trying to launch the re-design of the IMA site this early AM and I am testing the pages... I am running into some strange CSS spacing thing. I have made a CSS file for the text. The HEADER for each page is not CSS scripted, but set at HEADING 2 and Arial, Helvetica, sans-serif.
For some reason, the text that has CSS applied to it is generating large line spaces in some spots and I had set the line spacing to normal.
You can view what I am talking about here:
http://www.indiemanagers.com/membership_benefits.htm
Any ideas why this might be happening? I am mainly viewing in IE6 with a 1024X768 browser window.
Thanks,
Nat
Do you think these spaces have to do with unclosed TD tags at all?
Could that be it? I am going blind from looking at code all night/morning... can someone check this page to see if the not closed TD is the culprit?
Oh lord... my eyes are crossing.... LOL
I have to get some sleep. I'll be back later on.... heee heee not much rest for the CSS challenged.
Nat,
I'm not seeing a problem with line spacing. Did you already solve your problem? I'll attach screenshots so you can see how I'm seeing your webpage in IE6 and Firefox 0.8.
The only real difference, if you want to call it that, is the little bit of extra spacing between lines in IE. I wouldn't say it's much more than 3-4 pixels spacing between lines. Have a look-see and tell me what you think.
First, the screenshot in Firefox 0.8.
It looks fine from here too. Just a note, though...I have seen spacing issues with </td> tags that were not on the same line as the last line of text. So...if you have unclosed </td> tags, I would guess that it could potentially give a spacing issue as well.
Always always close tags, leaving them open is like dropping litter! (and when your doing coding, closing tags means its one less headache to have when it all goes wrong!)
Jimuni
Jimuni
I have been going thru this code and I can't see where I haven't closed a tag... it is a lot to examine tho... so maybe I am missing something...
The following is one of the pages that has the line spacing issues. Now, what is interesting is that these line spacing issues are only showing up when I view the page with IE 6.
As you can see, the line spacing issue starts after the bit of code that displays the inline frame ticker. <ilayer id="tickernsmain" width=&{tickerwidth}; bgcolor=&{tickerbgcolor}; visibility=hide>
<layer id="tickernssub" width=&{tickerwidth}; left=0 top=0></layer>
</ilayer>
Here is a link to the index page
This is the INDEX page code:
<html>
<head>
<title>IMA | Indie Managers Association | HOME</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="styles/ima.css" type="text/css">
<style>
BODY{
scrollbar-face-color:#663333;
scrollbar-arrow-color:black;
scrollbar-track-color:#663333;
scrollbar-shadow-color:'#663333';
scrollbar-highlight-color:'#cc9999';
scrollbar-3dlight-color:'#993366';
scrollbar-darkshadow-Color:'#cc9999';
</style>
<script language="JavaScript">
function MM_reloadPage(init) {  //reloads the window if Nav4 resized
  if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) {
    document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }}
  else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload();
MM_reloadPage(true);
function MM_swapImgRestore() { //v3.0
  var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a)&&x.oSrc;i++) x.src=x.oSrc;
function MM_displayStatusMsg(msgStr) { //v1.0
  status=msgStr;
  document.MM_returnValue = true;
function MM_preloadImages() { //v3.0
  var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a.indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a;}}
function MM_findObj(n, d) { //v4.0
  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[n];
  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers.document);
  if(!x && document.getElementById) x=document.getElementById(n); return x;
function MM_swapImage() { //v3.0
  var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
  if ((x=MM_findObj(a))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<meta name="metastatement" content="The Indie Managers Association (IMA) provides a unique opportunity for independent music managers to exchange ideas, suggestions and opinions amongst themselves and others on issues surrounding their independent community.">
<meta name="keywords" content="home, index, IMA, Indie Managers Association, Music, Music Manager, IMMA, Independent Music Managers Association, Managers, Management, Music, Independent Managers, Managers Association, Management Association, Music Organizations, Music Managers, Personal Managers, Road Managers, Tour Managers, IMMA, Music Conferences, Music Books, Music Directory">
<meta name="description" content="The Indie Managers Association (IMA) provides a unique opportunity for independent music managers to exchange ideas, suggestions and opinions amongst themselves and others on issues surrounding their independent community.">
</head>
<body leftmargin="0" topmargin="0" marginwidth="0" marginheight="0" onLoad="MM_preloadImages('navigation/nav_bar_r2_c2_f2.gif','navigation/nav_bar_r2_c4_f2.gif','navigation/nav_bar_r2_c6_f2.gif','navigation/nav_bar_r2_c8_f2.gif','navigation/nav_bar_r2_c10_f2.gif','navigation/nav_bar_r2_c12_f2.gif','navigation/nav_bar_r2_c14_f2.gif','navigation/nav_bar_r2_c16_f2.gif','navigation/nav_bar_r2_c18_f2.gif','navigation/nav_bar_r2_c20_f2.gif','navigation/nav_bar_r2_c22_f2.gif')" bgcolor="#663333" link="#FFFFFF" vlink="#666666" alink="#000000" background="layout/scanline2.gif">
<table width="760" border="8" cellspacing="0" cellpadding="0" align="center" bordercolor="#cc9999">
  <tr>
    <td bgcolor="#663333" height="0" valign="top" align="center">
      <table border="0" cellpadding="0" cellspacing="0" width="760" align="center">
        <!-- fwtable fwsrc="topbar.png" fwbase="topbar.png" fwstyle="Dreamweaver" fwdocid = "742308039" fwnested="0" -->
        <tr>
          <td><img src="layout/spacer.gif" width="136" height="1" border="0"></td>
          <td><img src="layout/spacer.gif" width="80" height="1" border="0"></td>
          <td><img src="layout/spacer.gif" width="1" height="1" border="0"></td>
        </tr>
        <tr>
          <td><img name="topbar_r1_c1" src="layout/topbar_r1_c1.jpg" width="136" height="150" border="0"></td>
          <td><img name="topbar_r1_c2" src="layout/topbar_r1_c2.jpg" width="136" height="150" border="0"></td>
          <td><img name="topbar_r1_c3" src="layout/topbar_r1_c3.jpg" width="136" height="150" border="0"></td>
          <td><img name="topbar_r1_c4" src="layout/topbar_r1_c4.jpg" width="136" height="150" border="0"></td>
          <td><img name="topbar_r1_c5" src="layout/topbar_r1_c5.jpg" width="136" height="150" border="0"></td>
          <td><img name="topbar_r1_c6" src="layout/topbar_r1_c6.jpg" width="80" height="150" border="0"></td>
          <td><img src="layout/spacer.gif" width="1" height="150" border="0"></td>
        </tr>
      </table>
<br>
      <table width="760" border="0" cellspacing="0" cellpadding="0">
        <tr>
          <td>
            <table border="0" cellpadding="0" cellspacing="0" width="760">
              <!-- fwtable fwsrc="nav_bar.png" fwbase="nav_bar.gif" fwstyle="Dreamweaver" fwdocid = "742308039" fwnested="0" -->
              <tr>
                <td><img src="navigation/spacer.gif" width="2" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="51" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="67" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="3" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="75" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="74" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="37" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="59" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="83" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="60" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="65" height="1" border="0" name="undefined_2"></td>
                <td><img src="navigation/spacer.gif" width="1" height="1" border="0" name="undefined_2"></td>
              </tr>
              <tr>
                <td colspan="23"><img name="nav_bar_r1_c1" src="navigation/nav_bar_r1_c1.gif" width="760" height="2" border="0"></td>
                <td><img src="navigation/spacer.gif" width="1" height="2" border="0" name="undefined_2"></td>
              </tr>
              <tr>
                <td rowspan="3"><img name="nav_bar_r2_c1" src="navigation/nav_bar_r2_c1.gif" width="2" height="13" border="0"></td>
                <td><a href="about.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Our history and our mission');MM_swapImage('nav_bar_r2_c2','','navigation/nav_bar_r2_c2_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c2" src="navigation/nav_bar_r2_c2.gif" width="51" height="10" border="0" alt="About the IMA"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c3" src="navigation/nav_bar_r2_c3.gif" width="2" height="13" border="0"></td>
                <td><a href="contact.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Ways you can get in touch');MM_swapImage('nav_bar_r2_c4','','navigation/nav_bar_r2_c4_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c4" src="navigation/nav_bar_r2_c4.gif" width="67" height="10" border="0" alt="Contact us"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c5" src="navigation/nav_bar_r2_c5.gif" width="3" height="13" border="0"></td>
                <td><a href="membership_benefits.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('What you get when you join the IMA');MM_swapImage('nav_bar_r2_c6','','navigation/nav_bar_r2_c6_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c6" src="navigation/nav_bar_r2_c6.gif" width="75" height="10" border="0" alt="IMA Member Benefits"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c7" src="navigation/nav_bar_r2_c7.gif" width="3" height="13" border="0"></td>
                <td><a href="membership_registration.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Register online or via mail');MM_swapImage('nav_bar_r2_c8','','navigation/nav_bar_r2_c8_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c8" src="navigation/nav_bar_r2_c8.gif" width="74" height="10" border="0" alt="Register Now!"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c9" src="navigation/nav_bar_r2_c9.gif" width="2" height="13" border="0"></td>
                <td><a href="faq.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Frequently asked questions');MM_swapImage('nav_bar_r2_c10','','navigation/nav_bar_r2_c10_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c10" src="navigation/nav_bar_r2_c10.gif" width="37" height="10" border="0" alt="FAQ"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c11" src="navigation/nav_bar_r2_c11.gif" width="3" height="13" border="0"></td>
                <td><a href="management_manual.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('One of the most definitive and up to date resources available for music managers today');MM_swapImage('nav_bar_r2_c12','','navigation/nav_bar_r2_c12_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c12" src="navigation/nav_bar_r2_c12.gif" width="59" height="10" border="0" alt="The IMA Management Manual"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c13" src="navigation/nav_bar_r2_c13.gif" width="3" height="13" border="0"></td>
                <td><a href="resources.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Helpful resources for the manager and artist');MM_swapImage('nav_bar_r2_c14','','navigation/nav_bar_r2_c14_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c14" src="navigation/nav_bar_r2_c14.gif" width="83" height="10" border="0" alt="Resources"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c15" src="navigation/nav_bar_r2_c15.gif" width="2" height="13" border="0"></td>
                <td><a href="industry_events.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Conferences, Showcases, Festivals, Seminars and more...');MM_swapImage('nav_bar_r2_c16','','navigation/nav_bar_r2_c16_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c16" src="navigation/nav_bar_r2_c16.gif" width="60" height="10" border="0" alt="Industry Events"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c17" src="navigation/nav_bar_r2_c17.gif" width="3" height="13" border="0"></td>
                <td><a href="seminar/about.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Seminar registration and information');MM_swapImage('nav_bar_r2_c18','','navigation/nav_bar_r2_c18_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c18" src="navigation/nav_bar_r2_c18.gif" width="75" height="10" border="0" alt="IMA Seminar Info"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c19" src="navigation/nav_bar_r2_c19.gif" width="3" height="13" border="0"></td>
                <td rowspan="2"><a href="membership_directory.htm" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Directory of Member and Non-Member Managers');MM_swapImage('nav_bar_r2_c20','','navigation/nav_bar_r2_c20_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c20" src="navigation/nav_bar_r2_c20.gif" width="83" height="12" border="0" alt="Management Directory"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c21" src="navigation/nav_bar_r2_c21.gif" width="3" height="13" border="0"></td>
                <td><a href="http://www.indiemanagers.com/" target="_top" onMouseOut="MM_swapImgRestore()"  onMouseOver="MM_displayStatusMsg('Back to the home page');MM_swapImage('nav_bar_r2_c22','','navigation/nav_bar_r2_c22_f2.gif',1);return document.MM_returnValue" ><img name="nav_bar_r2_c22" src="navigation/nav_bar_r2_c22.gif" width="65" height="10" border="0" alt="HOME"></a></td>
                <td rowspan="3"><img name="nav_bar_r2_c23" src="navigation/nav_bar_r2_c23.gif" width="2" height="13" border="0"></td>
                <td><img src="navigation/spacer.gif" width="1" height="10" border="0" name="undefined_2"></td>
              </tr>
              <tr>
                <td rowspan="2"><img name="nav_bar_r3_c2" src="navigation/nav_bar_r3_c2.gif" width="51" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c4" src="navigation/nav_bar_r3_c4.gif" width="67" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c6" src="navigation/nav_bar_r3_c6.gif" width="75" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c8" src="navigation/nav_bar_r3_c8.gif" width="74" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c10" src="navigation/nav_bar_r3_c10.gif" width="37" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c12" src="navigation/nav_bar_r3_c12.gif" width="59" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c14" src="navigation/nav_bar_r3_c14.gif" width="83" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c16" src="navigation/nav_bar_r3_c16.gif" width="60" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c18" src="navigation/nav_bar_r3_c18.gif" width="75" height="3" border="0"></td>
                <td rowspan="2"><img name="nav_bar_r3_c22" src="navigation/nav_bar_r3_c22.gif" width="65" height="3" border="0"></td>
              </tr>
              <tr>
                <td><img name="nav_bar_r4_c20" src="navigation/nav_bar_r4_c20.gif" width="83" height="1" border="0"></td>
              </tr>
            </table>
</td>
        </tr>
      </table>
      <br>
      <table width="90%" border="0" cellspacing="0" cellpadding="0">
        <tr>
          <td height="0">
            <table width="100%" border="0" cellspacing="0" cellpadding="0">
              <tr>
                <td width="16%" align="left" valign="top" height="0">
                  <h2><font color="#cc9999" face="Arial, Helvetica, sans-serif">Home
                    <script language=JavaScript>
//Disable right mouse click Script
//By Maximus (maximus@nsimail.com) w/ mods by DynamicDrive
//For full source code, visit http://www.dynamicdrive.com
var message="Function Disabled!";
function clickIE4(){
if (event.button==2){
alert(message);
return false;
function clickNS4(e){
if (document.layers||document.getElementById&&!document.all){
if (e.which==2||e.which==3){
alert(message);
return false;
if (document.layers){
document.captureEvents(Event.MOUSEDOWN);
document.onmousedown=clickNS4;
else if (document.all&&!document.getElementById){
document.onmousedown=clickIE4;
document.oncontextmenu=new Function("alert(message);return false")
</script>
                    </font></h2>
                </td>
                <td width="84%" height="0" valign="top" align="center"><a href="seminar/about.htm" target="_top"><img src="images/home/filmtvseminar.gif" width="405" height="81" alt="Click Here To Register For the IMA Film/TV Licensing Seminar" border="0"></a></td>
              </tr>
            </table>
            <table width="100%" border="0" cellspacing="10" cellpadding="0" align="center">
              <tr>
                <td width="20%" height="0" align="center" valign="middle">
                  <div align="left">
                    <p align="center" class="ima"><b><br>
                      </b></p>
                    <p align="center">
                    <div align="center" class="ima"><b>Subscribe To The IMA Mailing
                      List</b> </div>
                    <form action="http://www.indiemanagers.com/cgi-bin/dada/mail.cgi" method=POST>
                        <p><b>
                          <input type="hidden" name="flavor" value="subscribe">
                          <input type="text" name="email" value="email address" size="16">
                          <input type="hidden" name="list" value="ima">
                          </b></p>
                        <p><b><br>
                          <input type="submit" value="Subscribe" name="submit">
                          </b></p>
                      </div>
                    </form>
                    <p></p>
                  </div>
                </td>
                <td width="80%" height="0">
                  <p align="left" class="ima"><b>The Indie Managers Association
                    (IMA) is organized and dedicated to serving the independent
                    music management community by adopting a code of ethics; providing
                    educational manuals; offering discounts on products and services;
                    supplying promotional resources; drafting quarterly newsletters
                    and creating opportunities to cultivate professional relationships
                    through the annual IMA convention. </b></p>
                  <p align="left" class="ima"><b>The greatest risk to today's
                    independent music community is the fact that many managers
                    are not well educated about the music business and how it
                    applies to and affects their clients. We feel that a well-educated
                    manager operating with a solid knowledge base and sound business
                    practices will run a better company and yield better results
                    for themselves and their clients.</b></p>
                </td>
              </tr>
            </table>
            <hr>
            <span class="ima"><b>
            <script language="JavaScript1.2">
Ticker Tape script-
© Dynamic Drive (www.dynamicdrive.com)
For full source code, installation instructions,
100's more DHTML scripts, and Terms Of
Use, visit dynamicdrive.com
//configure tickercontents[] to set the messges you wish be displayed (HTML codes accepted)
var tickercontents=new Array()
tickercontents[0]='SEE WHAT MUSIC INDUSTRY PROFESSIONALS ARE SAYING ABOUT MANAGERS AND MANAGEMENT:'
tickercontents[1]='QUOTES FROM MUSIC INDUSTRY PROFESSIONALS ABOUT MANAGERS'
//configure the below 2 variables to set the width/background color of the ticker
var tickerwidth='100%'
var tickerbgcolor='black'
//configure the below variable to determine the delay between ticking of messages (in miliseconds
var tickdelay=3000
////Do not edit pass this line////////////////
var currentmessage=0
function changetickercontent(){
document.tickernsmain.document.tickernssub.document.write(tickercontents[currentmessa
e])
document.tickernsmain.document.tickernssub.document.close()
else
crosstick.innerHTML=tickercontents[currentmessage]
if (currentmessage==tickercontents.length-1) currentmessage=0
else currentmessage++
setTimeout("changetickercontent()",tickdelay)
function start_ticking(){
document.tickernsmain.visibility="show"
else
crosstick=document.getElementById? document.getElementById("tickerie") : document.all.tickerie
if (document.all||document.getElementById)
document.write('<div id="tickerie" style="width:'+tickerwidth+'; background-color:'+tickerbgcolor+'"></div>')
window.onload=start_ticking
</script>
            </ilayer>
            </b></span>
            <p><span class="ima"><b>Q:</b> <b>Considering record labels are less
              and less concerned with developing new artists and instead want
              a ready-to-go package, who do you think will be primarily responsible
              for developing new artists in the future? </b> </span> </p>
            <p><span class="ima"><b>A:<font color="#000000"> </font></b>It's what
              we are doing as managers. We have very close and intimate relationships
              with our artists and our job is to sit and listen to their vision
              for the band and to help them find opportunities to fulfill that
              vision. Managers are in the best position to help develop artists,
              but that's not to say that we don't need help from the label, because
              we do.</span></p>
            <p><span class="ima"><i>Quote by Tim Cook, who manages rock bands
              P.O.D. (US multi-platinum) and Stockholm Sweden's, Blindside (US
              Top 40).<br>
              Interviewed by Jean-François Méan - May 3, 2004 -
              <b><a href="http://www.hitquarters.com"'>http://www.hitquarters.com"'>http://www.hitquarters.com"'>http://www.hitquarters.com"'>http://www.hitquarters.com"'>http://www.hitquarters.com"'>http://www.hitquarters.com"'>http://www.hitquarters.com"'>http://www.hitquarters.com" target="_blank">HitQuarters.com</a></b></i>
              </span> </p>
            <hr>
            <span class="ima"><b>Q: How did you get started in the music business
            and how did you become an A&R? </b> </span>
<p><span class="ima"><b>A:</b> I started in artist management working
              for Dick Scott, who managed New Kids on the Block, Teddy Riley and
              Marky Mark. At the time, I also had a production deal with Epic
              Records. Essentially, I have always been an A&R because, whether
              as a manager or running a production company, I have always been
              involved with the creative side. Most of the skills I have acquired
              that help me as an A&R come from my experiences in management.
              As a manager, you learn every aspect of the music business: retail,
              marketing, radio, A&R, and promotion.</span></p>
            <p><span class="ima"><i>Quote by Bryan Leach, who is head of urban
              A&R at TVT Records in New York. The artists he represents include
              Lil Jon & The East Side Boyz (US Top 3) and the Ying Yang Twins
              (US Top 10).<br>
              Interviewed by Jean-François Méan - April 5, 2004
              <b><a href="http://www.hitquarters.com" target="_blank">HitQuarters.com</a></b></i>
              </span> </p>
            <hr>
            <span class="ima"><b>Q:</b> <b>What experiences have helped develop
            your skills as an A&R? </b> </span>
<p><span class="ima"><b>A:</b> My background in management is incredibly
              valuable. Four years of day-to-day management, of dealing with all
              the departments at major record labels teaches you how to plan the
              development of an artist and his or her record. When I became an
              A&R rep myself, I knew exactly what needed to be done, what
              format to go to radio with, how to roll out sales programs, and
              so on. My background had given me an understanding of the process
              that needs to take place at a major label to support an act's success.I
              would say that fifty percent of the things that are worth signing
              come from a manager, agent or lawyer you might know. The fact that
              artists have representatives shows that they are professional and
              are at a certain level.</span></p>
            <p><span class="ima"><i>Quote by Jaime Feldman, who is a rock A&R
              representative at EMI/Capitol in Los Angeles and the A&R for
              Bonnie Raitt (US multi-platinum).<br>
              Interviewed by Jean-François Méan - March, 15 2004
              </span> </p>
            <hr>
            <span class="ima"><b>Q: Considering record labels are less and less
            concerned with developing new artists and instead want a ready-to-go
            package, including well-produced songs, do you think it will be managers
            who are primarily responsible for the development of new artists in
<p><span class="ima"><b>A:<font color="#000000"> </font></b>Good managers
              will be. If you have an artist, and I don't care how talented he
              or she is, who can't do an interview, then they're not useful to
              you. If they can't sit down and have an intelligent conversation,
              they're not useful to you, and if they're walking around getting
              high or drunk, then they're not useful to you either. Artists have
              to take it seriously; you wouldn't go to work high or drunk, and
              if you're inarticulate, it's just going to make you look bad in
              the long run. Artists have to take it upon themselves to watch real
              interviews, to learn. I even watch interviews on CNN to see how
              they do it, to learn what and what not to say, how to say it and
              how to hold the mic. Artists must learn everything that being a
              performer involves, including how to perform in videos, and good
              managers will help them to do that. Labels, on the other hand, won't
              be of any help in this respect-I can't remember the last time I
              met somebody at a label who did artist development.</span></p>
            <p><span class="ima"><i>Quote by Scott Johnson, who manages the rap
              artist and producer David Banner (US Top 10), signed to SRC/Universal.<br>
              Interviewed by Kimbel Bouwman - March, 10 2004 <b><a href="http://www.hitquarters.com" target="_blank">HitQuarters.com</a></b></i>
              </span> </p>
            <hr>
            your skills as a manager? </b> </span>
<p><span class="ima"><b>A: </b>There's no school for managers, you
              have to learn it in the field as you go. Personal contacts are what
              it takes. For example, I know every head of every local record company
              around the world. You may have an artist who sold well in Benelux,
              but can't sell in the UK, and you have to understand why. You have
              to understand what the formats are and how you break artists in
              new markets. The only way to know that is by dealing directly as
              a manager with the heads of record companies, with marketing people,
              and with all sorts of companies around the world. I've developed
              that over the years and it's very important for a manager. It's
              a tough business though, particularly for managers, who get none
              of the credit but all of the blame.</span></p>
            <p><span class="ima"><b>Q: Do you think managers will be primarily
              responsible for the development of new artists in the future? </b>
              </span></p>
            <p><span class="ima"><b>A: </b> Without a doubt, because I think that
              the record business is going through a major upheaval right now
              and they're going to have to cut costs. Managers and producers are
              going to become very important in the development of artists, especially
              when the record company listens to you and you can create an intelligent
              marketing plan, as a manager in my position can. When a record company
              sees that you know what you're doing, then they will really work
              with you and that's very important for management. You just can't
              say let's spend this and let's spend that; you have to have a plan
              that works and I've been lucky enough in my career to have come
              up with them.</span></p>
            <p><span class="ima"><i>Quote by Brian Avnet, who currently manages
              Josh Groban (US multi-platinum) and Toni Braxton (US multi-platinum).<br>
              Interviewed by Jean-François Méan - February, 16 2004
              </span> </p>
            <hr>
            <span class="ima"><b>Q: Aside from Sean Paul's connection with the
            US hip-hop market, were other factors important? </b> </span>
<p><span class="ima"><b>A:<font color="#000000"> </font></b>The most
              important thing, something that I had never seen in my twenty-five
              years of working with Jamaican reggae artists, was a team around
              Sean Paul with experience and an international vision. Especially
              his manager, Jeremy Harding, who had also produced a fair amount
              of tracks for Sean Paul. I really had the best in Jamaica all working
              on Sean and that team, which also included Steve Wilson and Jerome
              Hamilton, gave me confidence right away and made me believe that
              it was going to work in America.</span></p>
            <p><span class="ima"><i>Quote by Murray Elias, who is Senior Director
              of A&R for Sean Paul (US platinum), Tanto Metro & Devonte,
              and Sasha, at VP Records.<br>
              Interviewed by Jean-François Méan - November, 14 2003
              </span> </p>
            <hr>
            <span class="ima"><b>Q:</b> <b>How important is the team around the
            artist?</b></span>
            <p><span class="ima"> <b>A:</b> Very important. A manager is a very important
              person because they serve as the liaison between the artist and
              the recording company and help to negotiate all aspects of the artist's
              deal. Once the band is on a label, then it becomes very important
              to have a great team in all departments.</span></p>
            <p><span class="ima"><i>Quote by Chris Morris, who is an A&R coordinator
              for urban and rock music at Atlantic Records. The artists he works
              with include T.I. and Nappy Roots (US platinum).<br>
              Interviewed by Kimbel Bouwman - October, 13 2003 <b><a href="http://www.hitquarters.com" target="_blank">HitQuarters.com</a></b></i>
              </span> </p>
            <hr>
            <p><span class="ima"><b>Q: What experiences have helped you to develop
              your skills as a manager? </b> </span></p>
            <p><span class="ima"><b>A:<font color="#000000"> </font></b>Lots of
              patience, reading and hands-on learning. You have to read about
              the business as well as work within it. I learned the ropes by working
              with Columbia and seeing how major labels are run. At the same time,
              it's the ups and downs, the good and the bad, the disagreements...I
              never stress out because knowledge is always a credit to you as
              a manager and as a person. Throughout the disagreements that you
              might have, you have to have done your research and make sure that
              you know what you're talking about.</span></p>
            <p><span class="ima"><i>Quote by Musa Moore, who is the president
              of Moore Flavor Entertainment and Mo' Flav Records. He has managed
              Profyle, Mobb Deep (US gold), Big L (US gold) and others.<br>
              Interviewed by Jean-François Méan - September, 30
              2003 - <b><a href="http://www.hitquarters.com" target="_blank">HitQuarters.com</a></b></i>
              </span> </p>
            <hr>
            <p><span class="ima"><b>Q: At what stage does a songwriter start to
              need a manager? </b> </span></p>
            <p><span class="ima"><b>A:<font color="#000000"> </font></b>In today's
              climate, many songwriters need management from the start. If they
              try to submit songs themselves and they don't have a publishing
              deal, a lawyer, or management, it's generally not going to get heard.
              And that's how it works with artists as well. At the same time,
              the writer really has to have something going creatively for a manager
              to take him or her on, whereas artists often just need someone to
              set schedules and provide guidance.</span></p>
            <p><span class="ima"><i>Quote by Michael Mavrolas, who heads Genuine
              Representation, a management company for songwriters and producers.
              His clients have written and produced songs for 2 Pac, Christina
              Aguilera, Brandy, Monica, Justin Timberlake, NAS, Anastacia and
              Destiny's Child, among others.<br>
              Interviewed by Jean-François Méan - July, 15 2003
              <b><a href="http://www.hitquarters.com" target="_blank">HitQuarters.com</a></b></i></span></p>
            <p><span class="ima"><b><font color="#FFFFFF"><a href="http://www.dcpages.com"><br>
              <img src="images/links/dcpages.gif" width="88" height="31" border="0" alt="DC Pages" hspace="5"></a><a href="http://www.dcmusicnews.com" target="_blank">DC
              Music News</a></font></b></span></p>
          </td>
        </tr>
      </table>
        <tr>
          <td height="0">
            <hr>
            <div class="imacopy">©2002-2004 IMA | <a href="http://www.mbstia.com/design.htm" target="_blank">Site
              Designed & Maintained by MBSTIA Design Division</a> | <a href="privacy.htm" target="_top">Privacy
              Policy</a> </div>
          </td>
        </tr>
      </table>
    </td>
  </tr>
</table>
</body>
</html>
Nat:
I do not see the problem (after your inline frame) :unsure: [with IE 6.0 view] ???
Sometimes in Dreamweaver (which I think my poor memory tells me you use), you will see funny spacing if you have a blank space before a </td> tag (or after a <td> tag for that matter).
Sorry of little help.
Good luck.
  • 2 weeks later...
This is very strange. Both my roomate and I see the line spacing problems in IE6 no matter how I try to tweak that code. I am running Windows 98SE and my roomate is running Windows XP. My screen resolution is 1024 by 768 32 Bit Tru Color setting and my roomate's system is 1024 by 768 32 Bit Highest Color setting.
We are running cable connected via ethernet.
Strange. Very strange.
  • 2 weeks later...
Nat, I'm not seeing it here with IE 6.0 either. Can you give us a screenshot so we can see what you are seeing? Maybe you are calling it funny spacing and we just don't know any better than to think you did it on purpose. :blink:
Also, if you use some of the validators such as validator.w3.org you can let it find unclosed tags and such for you. Any time I have something totally goofy I go there and let it find the things it can and it often gets the culprit. Just ignore the "Required attribute ALT not specified." and such unless you just want to be in compliance. On your page at www.indiemanagers.com/ it has the following abbreviated problems:
Line 337, column 106: end tag for element "DIV" which is not open
Line 340, column 44: an attribute value must be a literal unless it contains only name characters
... <ilayer id="tickernsmain" width=&{tickerwidth}; bgcolor=&{tickerbgcolor}
^ the & sign is what's causing the error.
I would guess that both of these could cause problems with spacing. There's also a CSS validator that can help with any problems in your stylesheets at jigsaw.w3.org/css-validator/
I don't know why you see it and we don't though. Keep plugging at it and you'll find it!
Hi Jim,
I've attached a screenshot showing what I am seeing here on both IE6 Browsers in this household.
I am going to check the codes again and use that very useful and helpful info you gave. Hopefully I can correct the issue. It's happening on most pages on this particular site.
Thanks,
Nat
I think I see what the difference is:
On the paragraphs that have the correct line spacing you have the class of "ima" assigned to the paragraph (ie: <p align="left" class="ima">)
On the paragrahps that are incorrect spacing you have "ima" assigned to span (ie: <p><span class="ima">)
Not sure why that causes the problem, (I am still learning css) but if you change all of your paragraphs to <p align="left" class="ima"> you should be good to go.
Hi Nat,
Kinda new at this css stuff myself.
But give this a try. In your css for .ima you have LINE-HEIGHT: normal;
Try something like LINE-HEIGHT: 14px;
Play around with the px size.
Hope that helps.
Greg
AHA!
One mystery solved. I still saw everything ok on your site in IE6 but then I went to the View -> Text Size and set it to medium, larger and largest and the problem became progressively worse. I have mine set to smaller by default so it didn't appear to be a problem.
Look at what GroovyFish said. I have seen that with Dreamweaver the thing does that very operation differently depending on some random number based on the phase of the moon, ambient room temperature and day of the week... sometimes it does <P class and other times it does <p><span class. I'm not sure exactly why but have had to make hand-changes before for that very reason.
If that doesn't pan out come back and we'll try something else. :(
