Hi- I have a web forum, it's PHPbb 2.0.5... Currently the mast head is this giant phpbb logo. How can I change it to the Teenage Republican logo? The web address is www.omtars.org/forum/
Eric, rename the logo you want to use to logo_phpBB.gif (it HAS to be a gif file or it wont work) and then upload it to forum/templates/subSilver/images/
If for some reason you want to use another filename for the image, you can edit the template file for the overall header of the webboard.
The file should be in <forum>/templates/<templatename>/overall_header.tpl
So if you're using the default subSilver template, the file should be in <forum>/templates/subSilver/overall_header.tpl
In that file, search for this bit of code
><img src="templates/subSilver/images/logo_phpBB.gif"
and simply change the "logo_phpBB.gif" to whatever filename you want to use.
Then upload the file you want to <forum>/templates/subSilver/images/ , just like Mike said.
Voilá, new logo on your webboard :rolleyes:
Step one, make a backup copy of /subsilver/overall_headers.tpl (rename backup to overall_headers.bak
Additionally you can change the link to go back to your main site by editing the overall_templates.tpl (in the subsilver directory) just a bit more....
find the line that includes
and change it to read
><TD HEIGHT=100 COLSPAN=3 ALIGN=CENTER VALIGN=MIDDLE WIDTH=175><A HREF="../index.html"><IMG ID="Picture10" HEIGHT=100 WIDTH=175 SRC="../assets/images/greatfolios_small_copy.gif" BORDER=0 ALT="Home"></A></TD>
(replace greatfolios_small_copy.gif with your own file name and remember this line assumes that the new logo is in your main_html/assets/images/ directory and that your logo is 100p high and 175p wide)
(feel free to correct code if you see an error in it, it works for my forum....)
Mr. Bill
  • 1 year later...
also need help please..
same question as the topic starter but I use phpBB 2.0.8a Setup. where and how can I find the forum/templates/subSilver/images/ to be able to change the image?
I can't find it through the administration panel. ;)
Thanks.
Humm... I had seen your post before but it seems I forgot to answer it, somehow. Sorry... :dance:
But I'm glad you got it working :dance:
Why's it has to be a .gif file?
I just upload my own pic and use that file name. Doesn't even have to be a .gif file extension when I do so. Because all the logo's I use for my boards have the .jpg file extension.
I don't remember noticing that on Mike's post the first time, but no, I don't think it has to be a GIF file either. I have used JPGs and PNGs and both worked just fine.
It has to be named logo_phpBB.gif if you do not want to edit the template.
