Strange Issue
KnitNut
Hello - I'm new to the forums and to TCH. I am experiencing a very strange issue. I cannot log onto my website (theknittingnut.net) on my computer. Not to the site, cpanel or WordPress dashboard. I use Firefox but I also tried it with IE. HOWEVER, I can log onto the site from my work computer - it just seems to be mine. I've cleared the cache and cookies and still can't get to my site. I'm running a virus scan but I'm pretty sure that's not the issue since I scan daily. I can get to other sites hosted by TCH though so I don't know what the problem is.... Any help/advice is apprecaited! :)
Thanks,
Robyn
sherlock holmes here.....
Your home IP address was blocked in our firewall. Looks like you attempted one to many incorrect FTP logins.
I have removed the block and restarted the firewall. You should be good to go.
# added 76.20.30.234 on 11/28/08 15:42:01 with comment: {bfd.pure-ftpd}
76.20.30.234
This has happened to me twice now. Once from FTP connections and one from CPanel log ins.
Can I just ask do the numbers add up over time? If so, are they ever flushed (like on a monthly basis) or do they continuously to add up?
They do not add up, as with most firewalls you have to hit a certain amount of failures in a certain time frame. I won't post those numbers but I promise if you trigger a failure today it won't be counted next month.
If you are getting blocked constantly, please open a ticket and we can work with you on what is causing the block.
Thanks,
Robyn
I'm having the same issues with www.sixfootzero.com. Probably the same FTP issue.
