gilk Posted July 3, 2006 Posted July 3, 2006 Where can I find tutorials for "Fantastico"? and I mean the great list that is contained in Fantastico... all I got up to now is a list of errors Quote
TCH-Thomas Posted July 3, 2006 Posted July 3, 2006 Welcome to the forum, gilk. What kind of errors do you get? What kind of tutorials do you want? Usually with all the installers in Fantastico, you should only need to click the install link for the script you want installed and follow the instructions and the script are installed are in its own folder. Quote
TCH-Bruce Posted July 3, 2006 Posted July 3, 2006 Welcome to the forums gilk. Along with following the instructions while installing there is always a link to the script author's site where you can find more information and help forums for a particular script. Quote
stevevan Posted July 3, 2006 Posted July 3, 2006 Welcome to the forums! Fantastico is basically a bunch of installers for the applications there. I've found most tutorials for those programs by either going to the author's site (as Bruce suggested) or by doing a google search. If you can provide us with specifics, someone will surely have a link to give you to the tutorial. Quote
abinidi Posted July 3, 2006 Posted July 3, 2006 If, when you are opening the link to Fantastico, you see a bunch of errors instead of scripts to install, you probably need to contact the help desk and have them take a look at the problem. Welcome to the forums!! Quote
gilk Posted July 4, 2006 Author Posted July 4, 2006 Thank you all, for sparing the time and trying to help. My question was in general. I've just seen the Fantastico, and it looks like some well of wealth :-) tried one (PHPproject), and didn't get any results. I was wondering what program to choose out of a few under each category. It would be a good idea, to add a link next to each program, just to shortcut the search procedure... after all, you all did it, so way go and do it a few more hundred of times? Quote
gilk Posted July 4, 2006 Author Posted July 4, 2006 (edited) I installed Gallery via fantastico, and it was fantastic! I started uploading pictures, and it was fine. I tried to view them - NADA! broken links. I found Gallery's help site, and found in the FAQs the exact problem: "I can successfully upload photos, but when I look in my album all I see are broken image icons. Why?" the answer was: "You've specified an incorrect path to your albums directory in the config wizard. You can fix this by re-running the Configuration Wizard and correcting the Albums URL value." as I understand it - the problem most be the fantastico script running the installation?!?! please advise... TIA Gil see: http://www.kenny.org.il/gallery_g/main.php Edited July 4, 2006 by gilk Quote
gilk Posted July 4, 2006 Author Posted July 4, 2006 (edited) I also tried running on the "system maintenance" "Build all thumbnails/resizes" and got: _____________________________________ - Build all thumbnails/resizes Tue 04 Jul 2006 04:38:02 AM EDT Success run now Ensure data files for all derivatives (thumbnails, etc) have been built and rebuild broken ones. Last Run Details: Checked 17 items 17 items built 17 items failed ___________________________________________ it said: Success, and it said 17 items failed... Edited July 4, 2006 by gilk Quote
nortk Posted July 4, 2006 Posted July 4, 2006 If the Fantastico installation is failing, you could open a ticket with the support people. In the meantime, you could download the latest Gallery version from gallery.menalto.com. This is recommended since the Fantastico installation does not have the latest version. Manually installing is pretty straightforward, and will alert you to any problems as you go. Quote
TCH-Bruce Posted July 4, 2006 Posted July 4, 2006 Fantastico is not something TCH put together it's a package that TCH has added to your account for your use. If you select one of the scripts provided in Fantastico there is a link on the right that will take you to the author's site where you can find more information. Quote
flashram Posted July 5, 2006 Posted July 5, 2006 Gilk when you click on each of the fantastico items you get a box in the righthand side. In there is a link to the site that is for the script so you can get further info for them. Don't install the scripts in the route directory. You are installing Gallery, install it in a directory that is gallery, make sure you keep everything in lower case as well. I have installed all the scripts from fantastico and installed them individually into their own directories which worked well and without any errors. That way I could keep track of the directories for uninstalling as well. How many databases does your hosting package allow for you, maybe that is a conflict you are having with the gallery software. Also do use spaces in your naming as well, you can use _ to seperate words. Try not to use common naming either as that conflict with paths etc as well. Quote
gilk Posted July 5, 2006 Author Posted July 5, 2006 (edited) How many databases does your hosting package allow for you, maybe that is a conflict you are having with the gallery software. Also do use spaces in your naming as well, you can use _ to seperate words. Try not to use common naming either as that conflict with paths etc as well. I'm not limited to # of DBs, so that's not the problem Gilk when you click on each of the fantastico items you get a box in the righthand side. In there is a link to I have installed all the scripts from fantastico and installed them individually into their own directories which worked well and without any errors. That way I could keep track of the directories for uninstalling as well. I didn't install a thing, only hit the link saying "install", and gave it a directory name "gallery_g". all lower case, no spaces. ... maybe I'll delete it all and try to re-install it...? Edited July 5, 2006 by gilk Quote
TCH-Thomas Posted July 5, 2006 Posted July 5, 2006 I would suggesting that you delete the current installation and try to reinstall it, but this time, try with a foldername without the underscore, like "gallery" and see if that works. I don´t know if the underscore is the problem, but its worth a try. If it still don´t work, open a ticket and ask the techs if there are any problems with Fantastico etc on your server. Link on top of page and in my signature. Quote
gilk Posted July 5, 2006 Author Posted July 5, 2006 (edited) 10X ! I'm trying Edited July 5, 2006 by gilk Quote
gilk Posted July 5, 2006 Author Posted July 5, 2006 did it all please see the attached file, where I documented the procedure I did...gallery.doc Quote
gilk Posted July 5, 2006 Author Posted July 5, 2006 gallery.docI deleted all galleries and re-install it. same problem! please see the attached file: Quote
TCH-JimE Posted July 5, 2006 Posted July 5, 2006 Actually this is pretty simple to solve. The reason you have this problem is that gallery uses imaging scripts like GD and Imagemagik to show the pictures and generate thumbnails. I am guessing that the basic install of gallery defaults to imagemagik which we do have here at TCH but you will need to configure it. So to fix this, log in as administrator, go to site admin and then look on the left hand side. You will see "toolkit priority". Move GD to the top and then goto "site maintaince" and choose to "build all thumbnails". Then logout and it should all be ok. If not, get back to me JimE Quote
gilk Posted July 5, 2006 Author Posted July 5, 2006 Actually this is pretty simple to solve. ....and then goto "site maintaince" and choose to "build all thumbnails". Then logout and it should all be ok. If not, get back to me JimE thank you! thank you! thank you! Quote
stevevan Posted July 5, 2006 Posted July 5, 2006 A picture is worth a thousand words! Glad you got it worked out! Quote
nortk Posted July 5, 2006 Posted July 5, 2006 I went to the link in the file you attached, and what I saw were the photos you uploaded...no broken links. When you reinstalled Gallery, did you use Fantastico, or did you delete everything and download the latest version and install from that? Quote
TCH-Bruce Posted July 5, 2006 Posted July 5, 2006 Topics merged. Please don't create duplicate threads. Quote
gilk Posted July 5, 2006 Author Posted July 5, 2006 I went to the link in the file you attached, and what I saw were the photos you uploaded...no broken links. When you reinstalled Gallery, did you use Fantastico, or did you delete everything and download the latest version and install from that? Well, that's because it was fixed later on. yocan see how on JimE's answer. Quote
