OK, i've been a customer for quite a while now, through many changes and have been happy with the support i've received in the past, mostly when i originally set up my site.
Today, I have a problem and unfortunately I dont think i have a login to the most recent help desk, so my first questions is can I get a login to that?
If not, maybe someone can help me figure out what may have happened with my phpbb forum. As of about 2 PM EST today, anyone who visited received this error:
phpBB : Critical Error
Could not obtain lastvisit data from user table
I was at work when it started, so dont know what caused it to fix it.
Another thing is, my domain emails are not working through MS OUtlook .. not sure if it is a related thing or not.
My chatroom, other subdomains, main domain site and everything else seem to be in working order.
Thanks in advance for any help I can get.
I just checked your forums and didnt get any errors. What server are you on? They had some issues with server 24 today so if you are on 24 that might have been the cause of your problem.
um.. did you try this link?
XTO Forums
http://xto.artamishia.com/xtoforum/
I know that the writing ones are ok, and they r the only ones i linked to from the main page of my site...
i just tried again, and got this error this time
Error doing DB query userdata row fetch
Truthfully, I dont even remember which server im on right now.. i thought 5 or 6 or something like that :D
OOPS The page http://www.artamishia.com/updates.htm needs to be updated. It sent you to the wrong place.
Either /forums is not available yet, or has been removed from the system.
Please email the webmaster and let them know about this error:
Webmaster
Sorry for the inconvenience.
www.artamishia.com
68.52.240.72
Mozilla/4.0 (compatible; MSIE 6.0; Windows 98)
404
That's the message I get when I try the link from your "updates" page..
ImaD
do you have two different forums installed? i just did a quick google search on that error, and altho i didnt find a resolution yet everything is saying it's due to having two forums and the database getting mismatched somehow
NP....I just don't know where the system default is for the BB that you use. I use the Invision board that I set up myself, so I'm at a loss to help you much.....but I know Leezard will come through....
:D
ImaD
That basically means that PHP can't access your database.
The question is: why?
There's two possibilities.
One is that you have the wrong username/password in the phpBB configuration but I'm setting that one asside since you said the forums were working fine.
The other one is that there's something wrong with the users table on your phpBB MySQL table.
If it's nothing serious, you should be able to go to CPanel, go to phpMyAdmin, select the database where you have the phpBB tables, select the "*_users" table and run the Check/Optimize/Repair/Analyze operations. I'm telling you to run them all because I'm not sure which one is the right one. Perhaps "Repair" but as I said, I'm not sure.
If that doesn't do it, then there's something else going on. In that case ,post here again and I'll try to help you out.
borfast beat me to it, after a little more digging I found out it's a problem with the tables, was going to suggest you go to phpmyadmin and repair each table.
