flashram Posted May 14, 2003 Posted May 14, 2003 I have in the past couple of days, been unable to view the source code of a webpage in Internet Explorer 6 by clicking View Source on the menue. All my defaults seem OK and updates are done, don't understand this problem. Has anyone got any suggestions at all regarding this. This is a major headache when looking at webpages and getting ideas on how something is done for webdesign and problem solving. Regards Peter Quote
Head Guru Posted May 14, 2003 Posted May 14, 2003 This issue is a know problem for the folks in Redmond. http://support.microsoft.com/default.aspx?...kb;EN-US;179829 http://support.microsoft.com/default.aspx?...b;en-us;Q306907 http://support.microsoft.com/default.aspx?...kb;en-us;203592 http://msdn.microsoft.com/library/?url=/wo....asp?frame=true Bottom line Delete your temp files for IE and increase the disk space for temp files and this problem will go away. Quote
flashram Posted May 14, 2003 Author Posted May 14, 2003 Thanks for the Heads up but that didn't work. I have tried all that previously, but did try it again, even deleted IE and reinstalled it, but still the same. I am running Windows 2000 by the way and most of the info relates to Win NT, WinME and Win98. Any other suggestions would be helpful. The funny thing is, it has only just happened in the past few days. Quote
Larry Posted May 14, 2003 Posted May 14, 2003 I run windows xp, and I tried the view source on the forum... It wouldn't let me Cleared my temporary internet files.. and WALLA I can view it now Gotta love Microsoft Quote
Head Guru Posted May 14, 2003 Posted May 14, 2003 Thanks for the Heads up but that didn't work. I have tried all that previously, but did try it again, even deleted IE and reinstalled it, but still the same. I am running Windows 2000 by the way and most of the info relates to Win NT, WinME and Win98. Any other suggestions would be helpful. The funny thing is, it has only just happened in the past few days. Buy a Imac Quote
greatfolios sysop Posted May 14, 2003 Posted May 14, 2003 I am also on w2k and ie6 same problem last 2 weeks or so. can't buy an iMac, my PC friends wouldn't let me live it down.... this has been a recent problem for me as I use it alot for troubleshooting my site. Guess I broke it. Good to see HG's posts around, kinda gives a warm fuzzy feeling in the forums. Mr. Bill Quote
TCH-Sales Posted May 14, 2003 Posted May 14, 2003 Another reason for not buying an iMac, nobody can afford it! Quote
Head Guru Posted May 14, 2003 Posted May 14, 2003 The imac post, was a joke. I have a mac.... it is in my bass boat, I use it for a anchor. Macs not spoken in my house.... Quote
KevinW Posted May 14, 2003 Posted May 14, 2003 Flashram -- suggest posting your issue at the appropriate Microsoft newsgroup - click here to locate them -kw Quote
flashram Posted May 14, 2003 Author Posted May 14, 2003 Thanks everyone, and Guru, if I wasn't locked into so much invested into Microsoft PC and other compatible software I probably would head down the Mac side. I also understood the IMac suggestion was a Joke, got it the first time. I eventually found the support newsgroups and after looking through all the recent replies came across the simple answer to the problem. Basically Don't have a shortcut to Notepad on your desktop named Notepad make sure it is named something else like Notepad2, that way the View Source Code works, tried it just now and instantainously fixed. All that for the past few days for something so simple. You would think that Microsoft would have put that in the Knowledge base by now, seems to have been an on going problems for a long time, by the sound of the replies in the newsgroups. Quote
Head Guru Posted May 15, 2003 Posted May 15, 2003 http://support.microsoft.com/default.aspx?...kb;EN-US;154168 Quote
