Sunshine80 Posted April 2, 2005 Posted April 2, 2005 when i go to my website all i get is a white page with blue text writing...i have read everything and i really do not know how to edit it any better...how do i change it so the frontpage will have a picture and stuff? thanks tiffany Quote
TCH-Tim Posted April 2, 2005 Posted April 2, 2005 You could get an editor such as Dreamweaver or CuteSITE Builder. Or learn to write HTML. Quote
Sunshine80 Posted April 2, 2005 Author Posted April 2, 2005 thanks i am just learning i know when i get the hang of it then it will be easy thanks so much Quote
Sunshine80 Posted April 2, 2005 Author Posted April 2, 2005 ok i used cute site builder i am reading everything but how do i add it to my website then? sorry for asking so many ??ss Quote
Sunshine80 Posted April 2, 2005 Author Posted April 2, 2005 (edited) i did what it said but its still not showing on the website i went to configure website is that where i fill out the info so i can publish it? Edited April 2, 2005 by Sunshine80 Quote
bellringr Posted April 2, 2005 Posted April 2, 2005 You might want to read this thread for beginners. Quote
TCH-Thomas Posted April 2, 2005 Posted April 2, 2005 ok i used cute site builder i am reading everything but how do i add it to my website then? sorry for asking so many ??ss As I understand from this you use CuteSite Builder (CSB)? If so click Configure website and follow the wizard. Then Click Publish website with the info provided here, but skip the part "Note: it will be necessary to first manually delete the default index.html file that TCH places in your web directory. You may do this by going to http://example.net/cPanel. It should not be needed. Let me know if you use CSB and have problems. Quote
Sunshine80 Posted April 2, 2005 Author Posted April 2, 2005 thanks thomas yes it is the cute builder i have done everything but where on the cpanel is the default index at?? i looked under index manager and did not see anything like that at all....is it somewhere else if so where thanks again tiffany Quote
TCH-Thomas Posted April 2, 2005 Posted April 2, 2005 I´m not sure I understand but if I do... When you have created your site in CSB you will automatically have a page named index.htm. When you publish your site the default indexpage will be overwritten. So there is no index page you should need to delete manually. If your CSB works correctly it will replace the indexpage. Quote
TCH-Thomas Posted April 2, 2005 Posted April 2, 2005 Addition, If this index.html does not get automatically overwritten you will need to either delete it through a ftp client (can´t give instruction about since all works differently) or through cpanel. If through cpanel, please do this; 1) Log in to yourtchsite.com/cpanel 2) Click on tab "file manager" 3) Locate public_html directory 4) Click the icon next to it (Do not click the underline) 5) Locate index.html 6) Click the line under index.html 7) To you right you should see several options, please click delete 8) Log out of everything 9) Republish site 10) All should be working. Hope this helps Quote
Sunshine80 Posted April 2, 2005 Author Posted April 2, 2005 (edited) IT WORKED THANKS THOMAS how do i update it? thanks so so so much you are all so wonderful its nice to have such a good support system! Edited April 2, 2005 by Sunshine80 Quote
TCH-Thomas Posted April 2, 2005 Posted April 2, 2005 No problem. Just glad I could help. As for updating it, now you just use CSB as usual and all updates should be visible right away. Quote
Samrc Posted April 3, 2005 Posted April 3, 2005 how do i update it? Just make changes to the design file and publish again. Only the pages with the changes will be uploaded to your website. Fast, easy. There is also a CSB specific discussion board on the globalscape website. http://www.globalscape.com/board/default.asp?b=1 -Samantha Quote
