How do I set up a mySQL thing so I can use it for phpBB. I am at the istallation of phpbb but I dont know what to type in the database server thing or the username/password. When I try to get it working it says it can't connect to the server. :D
Please Help!!
Phate
How are you installing phpbb? The easiest way to install it is to go to the cPanel and install the Bulletin Board under the cgi scripts section. It will prompt you for a subdiretory name (I used forum) and do all the work for you.
So I just go to the cpanel and install the bulletin board from there. do i have to install phpbb or anything. what do i have 2 do?
Phate
The Bulletin Board option on the cPanel is PhpBB so if you install it from there it will set up the database and user name as well as all the config settings to run the board. It will be set up with your cPanel login name as administrator so you can log in to the admin section using your cPanel login info and set things up like you want. I set one up to play with it some time back and found it to be pretty straight forward.
it still doesnt work :( it says "could not connect to the database."
my website address is www.wrestlingaction.com
what do i put as the database server hostname?
Is the database called XMB1? Is my username XMB1 too?
This all confuses me!!
I really need to get this thing workig. please...if any1 can help me work out what to type into the boxes on the phpbb installation screen I would be very appreciative.
Phate
I'm on my way out of town for the day, but you can try the following:
what do i put as the database server hostname? localhost
Is the database called XMB1? yes, you may try yourusername_xmb1
Is my username XMB1 too? no, your cpanel username
Sorry, I can't stick around and help.
I'll be back this evening.
Lianna
Lianna
so for the database server hostname i put www.wrestlingaction.com
for the database name I would put wrestli_xmb1
for the username I would put wrestli
for the password I would put the cPanel password
and for all of the administration things (username and password) i could put whatever I want??
Is all of that right or have I dont something wrong.
the forum is at http://www.wrestlingaction.com/forum and it goes straight to an index.php file.
If any1 knows what to do or can confirm that I am doing everything wrong then please reply to this.
Thanks.
Phate
Installing phpbb via the cPanel is as easy as everyone has said it is - even I did it! Listed below are the instructions I wrote down when I did it. I'm wondering if your problem is associated with the fact that you tried to down load and install phpbb manually rather than using cPanel.
If so, suggest you go to the TCH help desk and drop a ticket there.
Here are my instructions for installing phpbb via cPanel:
Setup:
1. Click on Tools, then Setup Forums/Bulletin Boards
2. Enter a directory name to be used (eg. forums), and click Install.
3. A confirmation screen appears. Click on Go Back.
Administration:
1. Point your browser to your forum using the following URL format:
http://www.******/forums where forums is the name you entered in step 2 above
2. Login using your main web site's account name and pasasword
3. The Administrative phpbb screen will appear
For what it's worth, it didn't quite work that way for me. After installing through cpanel, then going to the forum page, I was presented with a phpBB Install page. Didn't take long to figure that out, but something seemed broken with the cpanel install of my test bb. When time comes for a live forum install, it would be nice for it to work as advertised. Dunno, may have to do with my registration being new. Other than a bit of newbie frustration, all is good at the moment though.
I just tried it out from the cPanel again and something indeed is broken. I have installed it twice before and was able to just jump right into the forum after the install. Now it runs the install program instead, asking for all the information that previously was set up automatically. To top it off, after getting everything set up it wouldn't automatically write the config file so I had to have it sent to me and then FTP it into place manually.
I too, am having problems installing phpbb. I believe i have done everything as directed, but i get the following message upon submit:
phpBB : Critical Error
Could not connect to the database
Was there a resolution to this?
cjrd
ps: I'm new here, so maybe I missed something along the way, but several people mentioned WMB, instead of phpbb which is all that's available on my cpanel. Also, the user manual refers to WMB, as well. Are there more bb systems available?
If I'm not mistaken there Phate's problem was resolved by Head Guru via a helpdesk ticket yesterday.
Perhaps that may be a better recourse for you as well. But the symptom is not the same in your case. Your symptom sounds more like a case of mistaken database name or config setting.
Can you give us some more information like the URL where we can see this error too? or the config settings that you entered (not the password of course)?
Thanks.
Lianna
ok, here's what i did and what happened.
i chose the bb option in cpanel, it took me to a phpBB Setup page
( http://www.danesmedia.com:2082/frontend/bl...on/cgi/xmb.html )
and asked me to define a top level directory which i called : forum
upon clicking the "install" button, i was take to phpBB Installation page
( http://danesmedia.com/forum/install.php )
it ask's for:
Basic Configuration (which is all pre-populated)
Database Configuration
Database Server Hostname / DSN: localhost
Your Database Name: cjrdanes_phpbb
Database Username: cjrdanes
Database Password: ******
Prefix for tables in database: phpbb_ (pre-populated)
Admin Configuration
Admin Email Address: [my email]
Domain Name: www.danesmedia.com
Server Port: 80 (pre-populated)
Script path: /forum/ (pre-populated)
Administrator Username: cjrdanes
Administrator Password: ******
Administrator Password [ Confirm ]: ******
I clicked the "Start Install" button and endede up with the error message i posted previously.
Likely as not, i did something wrong, but I think i did what i was supposed to. I didn't want to open (yet another) ticket if i was just being stupid.
yep, likely it's the database name itself:
xmb# is usually the db name. Please go to cPanel and click the link to Manage MySQL. That should tell you on that page what your database name is.
cjrdanes_xmb1 probably is my guess
Also then your table prefix will be xmb1_
Again, let me know.
Lianna
PS:
The *just being stupid* syndrome doesn't work here! You are more than welcome to open a helpdesk ticket for ANY problem that you might be having short of your dog has eaten your favorite shoes! K? :rolleyes:
OK got it.
Just in case anyone follows this thread, I think what threw me was the pre-populated tabel prefix: phpbb_
I got on the wrong track because I was using phpbb instead of XMB, and didn't realise that the pre-populated prefix was wrong and needed changed.
after downloading and then uploading the config.php file (don't ask me, i just followed the directions till they worked) , it appears that all is well. Now i just have to learn to customise the forum, lol.
Thanks for everything!
