Help, please anyone...
I have spent many sleepless hours at my CPanel and cannot figure out what I am doing wrong. I would appreciate any help offered.....
I have uploaded my html and gif files into my file manager, under public.html. I got the messages (several times) about the upload "success".
Now, when I go to my website, there is nothing there but a directory. It is at:
www.ajpoa.org
Thanks for any help offered!!!
Char Rock Sign
It looks like the files are in the root directory rather than the publi_html directory. You can move them in Cpanel or use an FTP program. I would recommend SmartFTP, CoreFTP, or Filezilla.
To upload the files in cPanel you should go to File Manager. THen click on the folder icon next to public_html, not on the name. Then you will be in the public_html directory. You can then click on Uplolad File and use it to upload. The first directory you enter in CPanel is not public_html but the root directory.
Now.... just one more question (for now..)
Does anyone know where I can find a calendar for my site to upload?....
Ok, I found the calendar and got it uploaded. Thanks for your help :lol:
I'm sure I'll be back........
That's pretty wide open. Can you be more specific about "calendar"? What functions would you like? Do you mean something like just a calendar that you find in the bank register of your checkbook, or something like the Outlook calendar (which can easily be published to your site), or some thing more interactive from online?
Big variation here.
