roadmap Posted July 17, 2003 Posted July 17, 2003 Can someone solve this puzzle? I'm receiveing this error. Parse error: parse error, unexpected '\"' in /home/ripthej/public_html/canibus/sources/functions.php on line 872 Fatal error: Cannot instantiate non-existent class: func in /home/ripthej/public_html/canibus/index.php on line 108 Here is where I think the problem lies but I dont see the problem. if ( ($ibforums->member['g_max_messages'] > 0) and ($ibforums->member['msg_total'] >= $ibforums->member['g_max_messages']) ) { $msg_data['TEXT'] = $ibforums->lang['msg_full']; } else { $ibforums->member['new_msg'] = $ibforums->member['new_msg'] == "" ? 0 : $ibforums->member['new_msg']; 1. $msg_data['TEXT'] = sprintf( $ibforums->lang['msg_new'], $ibforums->member['new_msg']); } Head Bash Quote
roadmap Posted July 17, 2003 Author Posted July 17, 2003 Wrapper script | > Script written by Matt Mecham | > Date started: 14th February 2002 | +-------------------------------------------------------------------------- */ //----------------------------------------------- // USER CONFIGURABLE ELEMENTS //----------------------------------------------- // Root path $root_path = "./"; //----------------------------------------------- // NO USER EDITABLE SECTIONS BELOW //----------------------------------------------- error_reporting (E_ERROR | E_WARNING | E_PARSE); set_magic_quotes_runtime(0); class Debug { function startTimer() { global $starttime; $mtime = microtime (); $mtime = explode (' ', $mtime); $mtime = $mtime[1] + $mtime[0]; $starttime = $mtime; } function endTimer() { global $starttime; $mtime = microtime (); $mtime = explode (' ', $mtime); $mtime = $mtime[1] + $mtime[0]; $endtime = $mtime; $totaltime = round (($endtime - $starttime), 5); return $totaltime; } } class info { var $member = array(); var $input = array(); var $session_id = ""; var $base_url = ""; var $vars = ""; var $skin_id = "0"; // Skin Dir name var $skin_rid = ""; // Real skin id (numerical only) var $lang_id = "en"; var $skin = ""; var $lang = ""; var $server_load = 0; var $version = "v1.1.2"; var $lastclick = ""; var $location = ""; var $debug_html = ""; function info() { global $sess, $std, $DB, $root_path, $INFO; $this->vars = &$INFO; $this->vars['TEAM_ICON_URL'] = $INFO['html_url'] . '/team_icons'; $this->vars['AVATARS_URL'] = $INFO['html_url'] . '/avatars'; $this->vars['EMOTICONS_URL'] = $INFO['html_url'] . '/emoticons'; $this->vars['mime_img'] = $INFO['html_url'] . '/mime_types'; } } //-------------------------------- // Import $INFO, now! //-------------------------------- require $root_path."conf_global.php"; //-------------------------------- // The clocks a' tickin' //-------------------------------- $Debug = new Debug; $Debug->startTimer(); //-------------------------------- // Require our global functions //-------------------------------- require $root_path."sources/functions.php"; $std = new FUNC; $print = new display(); $sess = new session(); //-------------------------------- // Load the DB driver and such //-------------------------------- $INFO['sql_driver'] = !$INFO['sql_driver'] ? 'mySQL' : $INFO['sql_driver']; $to_require = $root_path."sources/Drivers/".$INFO['sql_driver'].".php"; require ($to_require); $DB = new db_driver; $DB->obj['sql_database'] = $INFO['sql_database']; $DB->obj['sql_user'] = $INFO['sql_user']; $DB->obj['sql_pass'] = $INFO['sql_pass']; $DB->obj['sql_host'] = $INFO['sql_host']; $DB->obj['sql_tbl_prefix'] = $INFO['sql_tbl_prefix']; $DB->obj['debug'] = ($INFO['sql_debug'] == 1) ? $_GET['debug'] : 0; // Get a DB connection $DB->connect(); //-------------------------------- // Wrap it all up in a nice easy to // transport super class //-------------------------------- $ibforums = new info(); //-------------------------------- // Set up our vars //-------------------------------- $ibforums->input = $std->parse_incoming(); $ibforums->member = $sess->authorise(); $ibforums->skin = $std->load_skin(); $ibforums->lastclick = $sess->last_click; $ibforums->location = $sess->location; $ibforums->session_id = $sess->session_id; list($ppu,$tpu) = explode( "&", $ibforums->member['view_prefs'] ); $ibforums->vars['display_max_topics'] = ($tpu > 0) ? $tpu : $ibforums->vars['display_max_topics']; $ibforums->vars['display_max_posts'] = ($ppu > 0) ? $ppu : $ibforums->vars['display_max_posts']; if ($ibforums->member['id'] and ( $std->my_getcookie('hide_sess') ) ) { $ibforums->session_id = ""; } $ibforums->base_url = $ibforums->vars['board_url'].'/index.'.$ibforums->vars['php_ext'].'?s='.$ibforums->session_id; $ibforums->skin_rid = $ibforums->skin['set_id']; $ibforums->skin_id = 's'.$ibforums->skin['set_id']; $ibforums->vars['img_url'] = 'style_images/' . $ibforums->skin['img_dir']; //-------------------------------- // Set up our language choice //-------------------------------- if ($ibforums->vars['default_language'] == "") { $ibforums->vars['default_language'] = 'en'; } $ibforums->lang_id = $ibforums->member['language'] ? $ibforums->member['language'] : $ibforums->vars['default_language']; if ( ($ibforums->lang_id != $ibforums->vars['default_language']) and (! is_dir( $root_path."lang/".$ibforums->lang_id ) ) ) { $ibforums->lang_id = $ibforums->vars['default_language']; } $ibforums->lang = $std->load_words($ibforums->lang, 'lang_global', $ibforums->lang_id); //-------------------------------- $skin_universal = $std->load_template('skin_global'); //-------------------------------- if ($ibforums->input['act'] != 'Login' and $ibforums->input['act'] != 'Reg' and $ibforums->input['act'] != 'Attach') { //-------------------------------- // Do we have permission to view // the board? //-------------------------------- if ($ibforums->member['g_view_board'] != 1) { $std->Error( array( 'LEVEL' => 1, 'MSG' => 'no_view_board') ); } //-------------------------------- // Is the board offline? //-------------------------------- if ($ibforums->vars['board_offline'] == 1) { if ($ibforums->member['g_access_offline'] != 1) { $std->board_offline(); } } //-------------------------------- // Is log in enforced? //-------------------------------- if ( (! $ibforums->member['id']) and ($ibforums->vars['force_login'] == 1) ) { require $root_path."sources/Login.php"; } } //-------------------------------- // Decide what to do //-------------------------------- $choice = array( "idx" => "Boards", "SF" => "Forums", "SR" => "Forums", "ST" => "Topics", "Login" => "Login", "Post" => "Post", "Poll" => "lib/add_poll", "Reg" => "Register", "Online" => "Online", "Members" => "Memberlist", "Help" => "Help", "Search" => "Search", "Mod" => "Moderate", "Print" => "misc/print_page", "Forward" => "misc/forward_page", "Mail" => "misc/contact_member", "Invite" => "misc/contact_member", "ICQ" => "misc/contact_member", "AOL" => "misc/contact_member", "YAHOO" => "misc/contact_member", "MSN" => "misc/contact_member", "report" => "misc/contact_member", "chat" => "misc/contact_member", "Msg" => "Messenger", "UserCP" => "Usercp", "Profile" => "Profile", "Track" => "misc/tracker", "Stats" => "misc/stats", "Attach" => "misc/attach", 'ib3' => 'misc/ib3', 'legends' => 'misc/legends', 'modcp' => 'mod_cp', 'calendar' => "calendar", 'buddy' => "browsebuddy", ); /***************************************************/ $ibforums->input['act'] = $ibforums->input['act'] == '' ? "idx" : $ibforums->input['act']; // Check to make sure the array key exits.. if (! isset($choice[ $ibforums->input['act'] ]) ) { $ibforums->input['act'] = 'idx'; } // Require and run require $root_path."sources/".$choice[ $ibforums->input['act'] ].".php"; //+------------------------------------------------- // GLOBAL ROUTINES //+------------------------------------------------- function fatal_error($message="", $help="") { echo("$message$help"); exit; } ?> Quote
TCH-JimE Posted July 17, 2003 Posted July 17, 2003 Hi, Well line 108 problem is due to a spelling error on line 108 of the index.php For instance, if you're calling "myClass", but the real class name is "My_Class", you will receive this error. I would start a help ticket and ask for your site to be restored back to when the forum was working. Jim Quote
roadmap Posted July 17, 2003 Author Posted July 17, 2003 Hi, Well line 108 problem is due to a spelling error on line 108 of the index.php For instance, if you're calling "myClass", but the real class name is "My_Class", you will receive this error. I would start a help ticket and ask for your site to be restored back to when the forum was working. Jim I forgot, wont they consider this a 3rd party issue therefore will not be able to provide any assistance? Quote
TCH-JimE Posted July 17, 2003 Posted July 17, 2003 Hi, Just ask for the site to be restored to a point where the forum worked Jim Quote
Head Guru Posted July 17, 2003 Posted July 17, 2003 Well I restored last nights backup and the problem still was present. So I then restored weekending backup and it looks like your forums are back up and running, but I am not sure if you want to go that far back on a backup. Please advise. Quote
roadmap Posted July 17, 2003 Author Posted July 17, 2003 I sent you an e-mail thanking you and also letting you know that it was fine. I just had to change the index.html to the main site because the old "comming soon" page was up. Im very greatful to everyone who took part in helping. The Rip The Jacker album comes out in a few short days and also the google bot just crawled my site so I needed everything in order. P.S. php is very sensitive I wouldnt suggest anyone alter anything in your scripts unless you know what you are doing. Im not even goning to add the radio back to the forum out of fear of what I might screw up. Thanks again! Dance Quote
