I was wondering if anyone has a favorite CMS they could recommend. There are so many to pick from! I've researched a few like php-nuke, eZ publish, etc., but am having trouble deciding. Any recommendations?
I use php nuke, if you wanna give it a test run there is an auto install available in your cpanel under add on scripts. It's an older version (6.0) but it will give you an idea of what you can do with it. If you decide you like it the latest version is available at phpnuke.org and is pretty easy to install.
I have it running at www.x-trememodz.com if you wanna check it out, also if you need any help with it just ask.
I really wish I had a legit reason to use e107 and I'd use it all the time.. lots of bells and whistles to use in it, and the setup is one of the easiest I've seen in a loong time. (Belive me, this job has me installing all kinds of stuff!)
