webgyrl Posted February 23, 2007 Posted February 23, 2007 Hi gang, Just wondering if anyone knows a work around for this. I noticed lately when i try to unzip my cPanel backups that I run into corrupted archive warnings. I have a feeling this is because the filenames are so long. I *thought* I had backups of all our site files, but this turns out not to be true because i can't unzip them using either WinRAR or WinZip. I keep getting archive corrupt messages. Does anyone know how I can rescue my site backups? Thanks! Quote
TCH-Don Posted February 23, 2007 Posted February 23, 2007 You might try TotalCommander to unzip the files. Just navigate to the file and double click it to view inside or select and then use the file menu to unzip to the other window. Quote
TCH-Andy Posted February 23, 2007 Posted February 23, 2007 I assume you have tried to fix a copy of them in winzip and winRAR. Since they were created on Linux - it may be worth trying to extract them there. Have you tried uploading one and then uncompressing it using the cpanel file manager? Alternatively - do a quick google on "advanced zip repair" and pick up a trial copy of the program. Quote
webgyrl Posted February 23, 2007 Author Posted February 23, 2007 You might try TotalCommander to unzip the files.Just navigate to the file and double click it to view inside or select and then use the file menu to unzip to the other window. Don, I will give this a try. What I think the problem is is this: I have lots of folders on my local drive. For all our web sites I have this set up Drive D Web Sites each site name has it's own folder I have in "sitefolder name" a BACKUPS folder in the backups folder I have a folder called "Complete Backups" so it's like this D:\\Web Sites\sitename\backups\complete backups I am thinking maybe when i go to extract it doesn't work well What's funny is that I grab backups of my Joomla sites from Joomla and I don't know why, but these ones unzip OK. I'll go get the info on Total Commander Thank You! Quote
webgyrl Posted February 23, 2007 Author Posted February 23, 2007 I assume you have tried to fix a copy of them in winzip and winRAR. Since they were created on Linux - it may be worth trying to extract them there. Have you tried uploading one and then uncompressing it using the cpanel file manager? Alternatively - do a quick google on "advanced zip repair" and pick up a trial copy of the program. Andy, What I did was to try to unzip the files different ways with winzip and winrar.. but no luck. If there is a fixer I missed, please let me know what to do or where to look. I have not tried uploading them to the server actually. i was trying to unzip them here to get access to files locally on my own computer when i was dong a Joomla upgrade. Some of the files were modified and I wanted to grab the old files to compare them to the new Joomla files so that in case I overwrite a modified file I can go back to the old one and fix it all up. I will google Advanced Zip Repair for sure. Thanks! Quote
Deverill Posted February 23, 2007 Posted February 23, 2007 Heya Natt!!! With Winrar select your .zip file and go to the menu Tools and under that is Repair Archive. That may work. You may also try making D:\backuptest and unzip to that to see if it's a problem with being nested so deep, but I doubt that's it. Also, if you have another hard drive try unzipping to it in case your file allocation table is full - if you have drives formatted FAT. I'm reaching here but it's worth a try. I too think your best bet is to unzip them in Linux but that doesn't get you what you need. Quote
jayson Posted February 24, 2007 Posted February 24, 2007 (edited) I use winrar for my backup, and have never had a problem maybe try a new download of either winzip or winrar Edited February 24, 2007 by jayson Quote
