kktran Posted July 11, 2003 Posted July 11, 2003 hi everyone, this is my first post, so sorry if i'm asking a dumb question. here goes: in implementing an image resizer, i discovered that i needed to change permissions on my destination folder. the only way i got it to work was to set the permissions to 777 (user: rwx, group: rwx, world: rwx) on the specified folder. but now i'm worried that i've just sent out an open invitation to hackers everywhere. the original permissions on the folder were 550 -- what should they be at minimum to allow my php script to write there? thanks in advance for your help! k* Quote
Mav2u Posted July 11, 2003 Posted July 11, 2003 I think you can use a 775 or even try a 644 and see if those work. But I guess it depends on what program your using. What script are you using? What's in the folder that you had to chmod to 777? Mav Quote
kktran Posted July 11, 2003 Author Posted July 11, 2003 thanks for the quick reply! Thumbs Up i'm using this script: http://kentung.f2o.org/scripts/thumbnail/resize.txt there's nothing in the folder (of course, until something is uploaded and written). it's the folder itself whose permission i had to change (i did this from the cPanel file manager). 775 and 644 don't seem to work. any other ideas? by the way, i'm using php. thanks! k* Quote
Mav2u Posted July 11, 2003 Posted July 11, 2003 I don't for see a problem with that being 777 chmod. I have a few folders that I use for php that I use with that setting because it does need to have full permissions to enact it processes. One of the TCH guru's will be able to tell you a little more about it for sure. Mav Quote
idallen Posted July 11, 2003 Posted July 11, 2003 All PHP code runs with the permissions of the userid of the web server, not with your userid's permissions. That means that you must give the web server permission to write in selected places in your account, and files created will be owned by the web server, not by you. The only way to let the web server write in your account using cPanel is to give parts of your account "general" write permissions (permissions for anyone to write), e.g. 666 for files and 777 for directories. The dark side of this is that anyone located on your server running PHP can write or delete those same files using their own PHP scripts, if they know where your files are. All PHP code has the same permissions, no matter where it is located or who runs it. Quote
TCH-Don Posted July 11, 2003 Posted July 11, 2003 Thanks Ian! So how or can we protect our files in this situation? Quote
kktran Posted July 11, 2003 Author Posted July 11, 2003 RE: ian yikes! that's what i had feared! is it possible to chmod 777 directly before and after our scripts need to write to that folder? (effectively, only allowing select "windows" of general access.) there must be some way to protect our folders; otherwise, it would seem that any server allowing back-end scripts write/exec access pose a security problem. in my case, i'm taking uploaded images, resizing them, and writing them to a specified directory. should i save myself the permissions hassle and simply save them into my DB? side question: do i take a performance hit by storing image files in my DB as opposed to simply leaving them in the file system? thanks! k* Quote
idallen Posted July 11, 2003 Posted July 11, 2003 So how or can we protect our files in this situation? there must be some way to protect our folders; otherwise, it would seem that any server allowing back-end scripts write/exec access pose a security problem. is it possible to chmod 777 directly before and after our scripts need to write to that folder? (effectively, only allowing select "windows" of general access.) You cannot protect any publicly-accessible files that are writable from PHP scripts on cPanel sites. If your PHP script can write these files, anyone on your server can write a PHP script to also write these files (if they know the file names). If the files were created by the PHP script, the files are owned by the web server ("apache"). That means your userid cannot change their permissions. Any PHP script you write to change their permissions can be over-ridden by any other user on your server writing another PHP script to undo what you did. (All PHP scripts have equal permissions.) If the files were created by you and given full write permissions (666) so that your PHP scripts could write them, then anyone else's PHP scripts can also write them. (In fact, with general write permissions, anyone on your server can write the files even using CGI scripts or a login shell account. General write permissions are a Very Bad Idea when you are hosted on a shared server.) No, you cannot securely create a folder with general write permissions (777), let PHP create some files in the folder, then remove the general write permissions (755). The folder is secure; but, the files are not. The files will be owned by the web server, and although only you can remove the files from your protected folder, any PHP script can overwrite them (because the files themselves are owned by the web server). Yes, you can create a file, give it 666 permissions, let a PHP script write it, then you can set it back to 644 permissions to protect it again. That does create only a small "window" of general access. The file must be owned by you; PHP cannot create such a file. (If PHP creates it, you can't change the permissions.) Corollary: Anything your PHP script can access can be accessed the same way by any other PHP script run by anyone sharing your server. So don't even use PHP to *read* sensitive data. NOTE: Unlike PHP, CGI scripts can be made secure. CGI scripts run using the userid of the owner of the script (your userid), not the owner of the web server. Therefore, your CGI scripts can read/write files that only *you* can read/write, and nobody can mess with them but you. Quote
TCH-Don Posted July 11, 2003 Posted July 11, 2003 So if I have a php form that reads a text file for the address to send to and I set them both to read, execute, no write is that safe? Quote
idallen Posted July 11, 2003 Posted July 11, 2003 So if I have a php form that reads a text file for the address to send toand I set them both to read, execute, no write is that safe? Depends what you mean by "safe". If the file is owned by you and has no general write permissions, and all the directories in which it resides are owned by you with no general write permissions, then PHP cannot write the file, rename it, or remove it from the directory. It's safe from writing. If the file has general read permissions, and the directories in which it resides all have at least general execute permissions, PHP can access and read the file. (Execute permissions on a Unix directory means "you can pass through this directory to the files it contains".) But, since PHP can read it, so can *all* PHP scripts written on your server, which might not be what you want if you want the address itself to be kept secret! Quote
TCH-Don Posted July 11, 2003 Posted July 11, 2003 (edited) Ok thanks, my goal is to make sure someone cannot rewite my config file to change where the form sends the data to. So If I put the two files mailit.php and the config text file in a folder with no write permissions and the files have no write permissions, and call mailit.php from another folder, I think my goal is accomplished. Edited July 11, 2003 by turtle Quote
idallen Posted July 11, 2003 Posted July 11, 2003 Note that when I said "directories" (plural), I really did mean *all* directories in the path from the root of the file system to your address file. If *any* of those directories has general write permissions, anyone's PHP (or CGI, or shell) script can rename or remove anything under that directory and replace it with its own stuff. On a shared server, make sure there are no general write permissions anywhere in your account. Quote
TCH-Don Posted July 11, 2003 Posted July 11, 2003 Thats sounds a little tough, since I have files in various place that I rewite. Oh well thanks for the info. Very educational Thumbs Up Quote
idallen Posted July 11, 2003 Posted July 11, 2003 Thats sounds a little tough, since I have files in various place that I rewite. If it is your userid that is doing the rewriting of your own files and directories, you don't need to give the files or directories general permissions; you need only grant specific permissions for your own userid. (Grant Unix "user" or "owner" permissions.) Granting yourself write permissions on your own files and directories does not let PHP scripts tamper with them. PHP needs general write permission ("other"-type write permissions in Unix-speak) to change your files or directories. Examples: File mode 644 - you (your userid) can read/write; everyone else (including PHP) can only read. Directory mode 755 - you can read/write/search; everyone else (including PHP) can only read and search. Nothing in your account should have general write permissions. Quote
TCH-Don Posted July 11, 2003 Posted July 11, 2003 Ah the light comes on! Thank you so much Ian Thumbs Up Quote
bstrouss Posted December 30, 2013 Posted December 30, 2013 I realize this topic is very old, but wondered if anything in Apache and/or MySQL or PHP had changed to plug this security hole on shared servers. Thanks! Quote
TCH-Bala Posted December 31, 2013 Posted December 31, 2013 Its been 10 years since the last post, lots of changes have been made to the server setup. Apache, PHP and MySQL has been upgraded many times since, but a major change I can point out is that we implemented suPHP, as mentioned HERE Quote
