Hello,
This occurred on my old vBulletin installation and my new Joomla installation, so I'm fairly sure it's a serverwide problem. The issue is that certain users, even after accepting all cookies, clearing them, and refreshing... Just cannot get logged into the site. Two of the users with issues both say they're using MSN, if that helps. One has parental controls turned on, the other does not.
Sometimes it will log them in, but if they click a link, they will immediately be logged out once again.
I appreciate any help or direction you can turn me for this problem!
Even though you reset cookie settings, did they clear temporary internet cache?
And have you verified that the case of the user name and password is correct (CAPS is not the same as CapS)
Are either of the people using accelerators to speed up connections (some of them can really interfere with many web features)?
Seems a little weird to be a server issue, but then again, anything is possible! Have you tried looking for anything like this in the Joomla! forums? Maybe someone else has had a similar situation.
And where are my manners? Welcome to the forums!
Edited by stevevan
First question, which i had to wrestle with alot it is, are the two bridged and if so what bridge are you using?
JimE
P.S Have they done the cookie dance?
step 1. log out
step 2. clear your browser cookie
step 3. clear your browser cache/temporary internet files
step 4. close your browser
step 5. go back and test
step 6. hold one foot in the air and spin around three time
singing "Do the Cookie Dance, yeah, yeah, yeah."
Hi eurrzcpa (how do you pronounce that?)
Are they using an out-of-browser cookie catcher like ZoneAlarm?
Do they have an alternate browser installed and, if so, do they get the same results?
Edited by Don
Thanks for the welcome! Yeah, I've had them clear the cache. That was my first instinct, but appears not to be the problem. Neither of them are using accelerators, the only thing they have in common are their use of MSN. I'm not sure if that's where the problem lies however.
Yeah I should take a look at the Joomla forums. The reason I came here though is because a similar issue was occuring on my vBulletin installation, making me think it goes beyond just Joomla.
step 1. log out
:) Yes I did the cookie dance, unfortunately to no avail. The two are not bridged, my license actually expired on vBulletin so i removed it from my server and started fresh with Joomla. So no connection between the databases or the login information.
I wish I knew how to pronounce it. I kept it as my forum username so I can remember it more easily :cool2:. I'm going to have them test with an alternate browser later today. They don't have anything like ZoneAlarm however.
Thanks for the suggestions everyone!
EDIT: TCH-Bruce - I've edited out your username - also there is a limit of 6 quotes per post. So I removed a couple of thank you replies.
Like Bruce says, if you think its a server issue, then please do submit a help desk ticket.
Gut instinct tells me its not though. Can you please both of you supply your Cookie details for the phpBB and what path the folder is that holds this install
Many thanks
JimE
