Domain Problem Or Isp Problem
perfectdreams
403 Forbidden
Forbidden You don't have permission to access /_vti_bin/_vti_aut/author.exe on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
I get that error when I try to update through FP. I've got FP 2002.
I can update through FTP without a problem. I can update using FP with another domain host without a problem. Only one i have problems with is my TCH domains :no2:
I've tried reinstalling, unistalling, all that with the extensions.
Please open a help desk ticket.
Techs will check if you have the front page extensions installed for your site and check that you have access to them
Yes, it is. Thank you so much.
Another plus to TCH: when there's a problem, it's fixed, right and fast :no2:
  • 3 weeks later...
If you found the same problem in future, please add this line in .htaccess file under public_html folder;
SecFilterEngine Off
That will resolve the issue ;)
Just wanted to say I had an identical problem on my other domain, tried this first, and BOOM! worked like magic :)
Double thanks!! :tchrocks:
