Aknot Posted May 25, 2003 Posted May 25, 2003 The page with the counter is: http://aa.facciolli.com/aaholes.htm Be forwarned there are some choice words on that page (ahole) and the following pages. Quote
Aknot Posted May 26, 2003 Author Posted May 26, 2003 hmmm sorry it seems like it is working now...... Quote
Aknot Posted May 26, 2003 Author Posted May 26, 2003 OK and now it is not. It was at 29 last night now it is at 1 and wont move. WHAT UP? Quote
leezard Posted May 26, 2003 Posted May 26, 2003 Are you using the counters available in Front Page? I've never had very good luck with them. Theres a counter in the Cpanel under CGI scripts that works well and you can customize it a lot. I played around with it, and most of the other scripts when I 1st signed up. Quote
Aknot Posted May 28, 2003 Author Posted May 28, 2003 Sorry been a little busy. Thanks for the replies. Yeah I seem to remember having problems in the past with FP counters. So I changed to a cgi hosted counter that also gives me stats. Thanks again for the replies. Quote
