Guest ykol20 Posted May 21, 2003 Posted May 21, 2003 when i try to enter it says "acces denied" on the page, how do i type in my username and password to get in, i never get the window to type it in before it shows the acces denied screen. any answer would be helpful, it might be a browser setting thats not popping up the password box. Quote
TCH-Rick Posted May 21, 2003 Posted May 21, 2003 Are you running some sort of pop-up stopper. That is an odd problem. As a work around for now, you might try getting into the cPanel by using the format http://username:password@ipaddress:2082. That should get you in. You might want to submit a Help Desk Ticket and let us be sure it's working correctly. Quote
Guest Guest Posted May 21, 2003 Posted May 21, 2003 still doesent work, my user name and pw for my site right, and the ip of the site, not my ip right? Quote
Larry Posted May 21, 2003 Posted May 21, 2003 are you behind any company firewall? that blocks your ie from gettin to ports other then port 80? Quote
Guest ykol20 Posted May 22, 2003 Posted May 22, 2003 now im sure its a problem with the password entry box popping up, it doesent and instantly goes to the acces denied screen, how can i fix this? Quote
Guest ykol20 Posted May 22, 2003 Posted May 22, 2003 nevermind, i got it to work by playing around with the settings, thnx for your help Quote
TCH-JimE Posted May 23, 2003 Posted May 23, 2003 Hi, If people have problems getting into something that requires a password, the best thing to do is to delete your cookies and history. Some times blocking all cookies will cause the same problem Jim Quote
