I have a small tower, Pent4 2.53, two 120g hard drives, 1.5 g ram, 350 power, two DVD drives.
This is what I get from speedfan and MBM and others on idle.
MotherBoard 49c
CPU 42c
Hard Drive1 45c
Hard Drive2 41c
Video Card 42c
Mother Board will go up to 56c on simple games.
Is this to high?
David
A lot of what contributes to heat is what surface you have the pc on, how much space around it and what kind of cooling you've implemented. If you're worried abou theat make sure the computer is on a hard, flat surface (no carpets) and has some room around it with good circulation. =)
70 Celcius is meltdown point.. I generally like to stay below 50 as a good rule of thumb.. any fan that does over 4500 RPM will do that for you. :P Mine tends to run around 42-44.
This is why I have four case fans, a cpu fan, the side of my case off and the entire thing submerged in flourinert cooled to 0 degrees C. Yeah, thats the ticket.
Ummm....I'm almost afraid to ask this because I'm giggling too hard....
How do you take your PC's temperature? ;)
Most modern day proccesors and mother boards support temperature and fan monitoring. (also voltage monitoring) If parameters fall above or below the settings you set they can set off alarms, shut down the system and even email you of the problems. Here is a screen shot of Motherboard monitor 5:
youneverknow
I was having a bit of fun - I do know that internal temps can create havoc. :)
Are there any other options besides Motherboard Monitor you'd recommend?
I'm working toward getting a new system and am often amazed that my 5 year old box has only ever had one major problem. The fan is the one thing I actually worry about and keeping the CPU well ventilated is the number one considertion for me. I've never thought of taking the shell off, I have a cat who is a gold medal class shedder. ;) Then again, I'm not running the space shuttle here, either.
OK, thats a lie. My Athalon runs at 57 with 3 case and one CPU and the side off.
I had heard it was important to keep the sides of the cases on to maintain the correct airflow within the case, and that while you might think that taking the sides off will help with cooling, you can actually have an opposite effect.
