I am trying to install a CGI-Script. I have a few silly questions (First time I am trying this!)
1) Am I correct to assume that the cgi-bin folder in www is the correct place for the "cgi-bin" ?
2) I installed the script and when I try it I get this message
"The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@sclhosts.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log."
So where do I find the error log ?
3) Is the .pl extensio ok or do I have to rename the files .cgi ?
Thanks for your help
Simon
Hi Simon :unsure:
Well, yes, /www/cgi-bin/ is the correct folder for your CGI scripts, so you got that one right ;)
But from the error message you mentioned, I think the problem might have to do with the permissions of the file. Try this: go to your CPanel's File Manager, navigate to the /www/cgi-bin/ folder, click the file you're trying to execute and then, on the right side of the page, you'll have a list of actions to perform on the file.
Select the "Change permissions" option and make sure every check box on the "Execute" column is checked.
And no, you don't need to rename the files' extension to .cgi, .pl should work just fine :)
If that doesn't work, post another message and we'll dig a little more to figure out what's wrong :)
Borfast,
thanks for replying. I made sure that the "Execute" box is checked but I still get the same message. I would look into the server error log if I knew where to find it.
Simon
Hi Simon.
The last thing that comes to my mind is to ask you if the script has the usual
>#!/usr/bin/perl
at the beginning...
I'm sorry, I'm not really a CGI/PERL expert :unsure:
If this isn't the answer to the problem and no one else knows how to solve it, submit a help desk ticket. It might even be a small problem with your account, or something.
Edited by borfast
You can see your error log in your CPanel (under Stats.) It is very useful at times. For example, directory is writable by all indicates that the permissions are set to 777 and you should change them to 755. Premature end of script headers or something similar may mean an extra space at the end.
Thanks for your help folks. I am really beginning to feel stupid.
I have now double checked that I have FTP-ed everything and CHMOD-ed everything as I should.
All the path for relevant directories are there, etc...
I still get that a file has no execute permission even after I changed it. To be double sure I did it through the File Manager from the cpanel.
Any other idea ?
Silly question of the year : If I change a file permission through the file manager, is the change immediate ?
thanks again
Simon
Richard,
yes... also I used the File Manager of cpanel to re-upload two files once I realised that I had the wrong path to the cgi-bin (I put www.sclhosts.com rather than /home/sclhost/public_html/cgi-bin )
Now they are error log talks about Premature End of the script. As you probably have gathered this is the first time I am dealing with perl. Thanks for your (and anybody else's) help
Simon
This is the code as uploaded :
!/usr/bin/perl
# CalendarScript
# Version: 3.2
# Copyright 2001,2002 Matt Kruse
# http://www.CalendarScript.com/
BEGIN {
# CHANGE THE LINE BELOW IF NECESSARY
# Be sure to remove the # before $BASE_DIR, and change the path between the quotes
$BASE_DIR = "/home/sclhost/public_html/cgi-bin/calendarscript/";
# DO NOT CHANGE ANYTHING BELOW HERE!
if ($BASE_DIR ne "") { $BASE_DIR =~ s|([^/])$|$1/|; }
else {
my ($path) = $ENV{'PATH_TRANSLATED'} || $ENV{'SCRIPT_FILENAME'};
unless ($path) {
print "Content-type:text/html\n\n<B>ERROR:</B><BR>Your server does not provide the PATH_TRANSLATED or SCRIPT_FILENAME environment variables.<br><br>Please see the installation documentation for how to set the \$BASE_DIR variable manually.";
exit(0);
$path =~ s|[^/\\]*$||;
$path =~ s|([^/])$|$1/|;
$BASE_DIR = $path . "calendarscript/";
unshift(@INC,$BASE_DIR."lib");
require "asp.inc";
require "DBFile.pm";
require "DBFileUtil.inc";
require "TimeLocal.inc";
require "Date.inc";
require "ConfigFile.pm";
require "Event.inc";
require "HTML.pm";
require "CGISession.inc";
require "User.pm";
require "SimpleDateFormat.pm";
require "calendars.inc";
sub ERROR {
my($msg,$severity) = @_;
&addUserMessage($msg);
&showScreen();
sub FATALERROR {
my ($msg) = @_;
&addErrorMessage($msg);
if ($in{template} eq "error.html") { print "FATAL ERROR: COULD NOT LOAD error.html"; exit(0); }
$in{template} = "error.html";
&showScreen();
# Load the required template and execute it
sub showScreen {
&populateTemplateVariables();
$template_dir = $BASE_DIR . "templates/calendars/" . $Config->get("template_dir") . "/";
$template_file = $template_dir . $in{'template'};
$template = &ASPLoadTemplate($template_file);
&ASPEval($template,$template_dir);
&ASPError($tmp_parsed_template) if $@;
exit(0);
sub showSameScreen() {
$in{'template'} = $in{'fromTemplate'} || "error.html";
&showScreen();
# Handle error messages
sub addUserMessage {
my($msg) = shift;
if ($msg ne "") {
$Template::userMessage .= $msg . "<BR>";
sub addErrorMessage {
my($msg) = shift;
if ($msg ne "") {
$Template::errorMessage .= $msg . "<BR>";
# Get message text to support language translation
sub getMessage() {
my ($name,$p1,$p2,$p3,$p4) = @_;
# Only read in the file if there is a message to be retrieved
unless ($MESSAGES) {
$msgfile = $BASE_DIR . "templates/admin/$admin_template_dir/messages.txt";
open(MESSAGES,$msgfile) || &FATALERROR("Error opening messages file [$msgfile]: $!");
while(<MESSAGES>) {
next if /^#/;
next unless /\S/;
chomp;
my($name,$value) = split(/=/,$_,2);
$MESSAGES->{$name} = $value;
close(MESSAGES);
my ($message) = $MESSAGES->{$name};
if ($message eq "") { return "MESSAGE TEXT MISSING FOR: $name"; }
if ($p1) { $message =~ s/\%s/$p1/; }
if ($p2) { $message =~ s/\%s/$p2/; }
if ($p3) { $message =~ s/\%s/$p3/; }
if ($p4) { $message =~ s/\%s/$p4/; }
return $message;
# Get a list of plugin files
sub getPluginFileList {
my ($file,$plugin);
my ($pluginfiles,$pluginsfilesfile);
$pluginsfilesfile = $plugins_dir."plugin_files.txt";
if (-e $pluginsfilesfile) {
open(PLUGINFILES,$pluginsfilesfile) || &FATALERROR(&getMessage("ERROR_OPENING_PLUGIN_FILES_LIST",$!));
while (<PLUGINFILES>) {
next if /^\s*(#|$)/;
chomp;
($file,$plugin) = split(/\t/);
unless (exists $pluginfiles->{$file}) {
$pluginfiles->{$file} = "plugins/$plugin/$file";
close(PLUGINFILES);
return $pluginfiles;
# Handle custom-defined functionality
sub handleCustomFunction() {
my ($funcName,@args) = @_;
my ($result) = 0;
my ($filename) = $funcName . ".pl";
if ($PluginFiles->{$filename}) {
$filename = $BASE_DIR . $PluginFiles->{$filename};
eval("require \"$filename\";");
if ($@) {
# Error including file - return error msg and continue running normal functions
&addUserMessage(&getMessage("ERROR_REQUIRING_CUSTOM_FUNCTION",$filename,$@));
return 0;
# Try to call custom function
eval("\$result = \&${funcName}(\@args);");
if ($@) {
# Error calling function - return error msg and continue running normal functions
&addUserMessage(&getMessage("ERROR_RUNNING_CUSTOM_FUNCTION",$funcName,$@));
return 0;
# Custom function was executed. Return whatever it returned.
return $result;
return 0;
# Get a Template Preference value, either from the config file or the default
sub getTemplatePreference {
my ($name) = @_;
my ($key) = "template_preference_".$Config->get("template_dir")."_".$name;
if ($Config->contains($key)) {
return $Config->get($key);
return $main::TemplateDefaults->{$name};
sub LZ { my($x)=shift;if(length($x)==1){return "0$x";}return $x; }
sub URLEncode {
my($url)=@_;
my(@characters)=split(/(\%[0-9a-fA-F]{2})/,$url);
foreach(@characters) {
if ( /\%[0-9a-fA-F]{2}/ ) {
unless ( /(20|7f|[0189a-fA-F][0-9a-fA-F])/i || /2[2356fF]|3[a-fA-F]|40/i ) {
s/\%([2-7][0-9a-fA-F])/sprintf "%c",hex($1)/e;
else {
s/([\000-\040\177-\377\074\076\042])/sprintf "%%%02x",unpack("C",$1)/egx;
return join("",@characters);
# Get input Data
sub getInput {
my ($in,@in,$key,$val);
my (@keys,%formvars);
if ($ENV{'REQUEST_METHOD'}) {
if ($ENV{'REQUEST_METHOD'} eq "GET") { $in = $ENV{'QUERY_STRING'}; }
elsif ($ENV{'REQUEST_METHOD'} eq "POST") { read(STDIN,$in,$ENV{'CONTENT_LENGTH'}); }
@in = split(/&/,$in);
# First get all the raw form vars
foreach $i (0 .. $#in) {
$in[$i] =~ s/\+/ /g; ($key, $val) = split(/=/,$in[$i],2);
$key =~ s/%(..)/pack("c",hex($1))/ge;
$val =~ s/%(..)/pack("c",hex($1))/ge;
# Keep a record of their order, because later values take precendent
push(@keys,$key);
$formvars{$key} = $val;
# Process the special QUERY_STRING field, if it exists
# These values come first and then might be over-written
if ($formvars{'QUERY_STRING'}) {
@in = split(/&/,$formvars{'QUERY_STRING'});
if ($val ne "") {
$in{$key} = $val;
if ($in{'datestring'} && (($key eq 'year') || ($key eq 'month') || ($key eq 'date'))) {
delete $in{'datestring'};
if ($key eq "datestring") {
delete $in{'year'};
delete $in{'month'};
delete $in{'date'};
delete $formvars{'QUERY_STRING'};
# Process all the new field values, over-writing the old ones
foreach $key (@keys) {
next if ($key eq "QUERY_STRING");
$in{$key} = $formvars{$key};
delete $in{'year'};
delete $in{'date'};
# Form the query string from form input
foreach $key (keys %in) {
if (($key eq "command") || ($key eq "username") || ($key eq "password") || ($key =~/^FIELD_/)) {
delete $formvars{$key};
next;
if ($QUERY_STRING ne "") { $QUERY_STRING .= "&"; }
$QUERY_STRING .= &URLEncode($key) . "=" . &URLEncode($in{$key});
$FORM_QUERY = join('&', map {"$_=$formvars{$_}"} keys %formvars);
elsif ($ENV{'DOCUMENT_URI'}) {
open(SSI,$BASE_DIR."ssi.txt");
while(<SSI>) {
chomp;
($key,$val) = ( /^\s*([^=]+)\s*=\s*"?(.*?)"?$/o );
$key =~ s|\s*$||;
$val =~ s|\s*$||;
next unless ($key);
$in{$key} = $val;
close(SSI);
$no_session = 1;
elsif ($#ARGV >= 0) {
while ($in = shift(@ARGV)) {
($key,$val) = split(/=/,$in);
$in{$key} = $val;
$no_session = 1;
$no_header=1;
# Here is all the dirty work... #
$|=1;
# Read the main admin config file
$admin_config = $BASE_DIR . "config.txt";
$AdminConfig = new ConfigFile($admin_config);
$Template::AdminConfig = $AdminConfig;
$admin_template_dir = $AdminConfig->get("admin_template_dir") || "English";
$plugins_dir = $BASE_DIR . "plugins/";
$PluginFiles = &getPluginFileList();
# Get input
unless(&handleCustomFunction("display_before_getInput")) {
&getInput();
&handleCustomFunction("display_after_getInput");
# Start output
if (($ENV{'HTTP_COOKIE'} =~ /CGISessionID/) || ($in{'command'} eq "login")) {
$Session = new CGISession($BASE_DIR . "session/");
unless ($no_session) {
my ($id) = ($ENV{'HTTP_COOKIE'} =~ /CGISessionID\s*=\s*([^;]*)/);
$Session->getSession($id);
if (($Session->isValid()) && ($in{'command'} ne "logout")) {
print "Set-cookie: CGISessionID=",$Session->getValue("_id"),";path=/\n";
else { print "Set-cookie: CGISessionID=;path=/;expires=Thu, 01-Jan-1970 00:00:00 GMT\n"; }
# Make session available in template files
$Template::Session = $Session;
unless ($no_header) {
print "Content-type: text/html\n\n";
$in{'calendar'} ||= $AdminConfig->get("default_calendar");
$in{'calendar'} =~ s|[^\w\d\._]||g;
$calendar = $in{'calendar'};
$in{'template'} ||= "default.html";
$in{'template'} =~ s|[^\w\d\._]||g;
$db_dir = $BASE_DIR . "calendars/" . $in{'calendar'} . "/";
$config_file = $db_dir . "config.txt";
$schedule_db = $db_dir . "schedule";
$events_db = $db_dir . "events";
$calendars_db = $BASE_DIR . "calendars";
$users_db = $BASE_DIR . "users";
$permissions_db = $BASE_DIR . "permissions";
# Read the config file for the calendar
$Config = new ConfigFile($config_file);
$Template::Config = $Config;
# Get calendar name, description
$Calendar = &getCalendarInfo($calendar);
# Get display options for the template set to be used
$TemplateFields = &GetFieldProperties($BASE_DIR."templates/calendars/".$Config->get("template_dir")."/preferences.txt");
foreach $field (@$TemplateFields) {
$TemplateDefaults->{$field->{'field_name'}} = $field->{'defaultvalue'};
# The CGI URL for call-back
$Template::CGI_URL = $AdminConfig->get("calendar_url") || $ENV{'SCRIPT_NAME'} || $ENV{'REQUEST_URI'};
$Template::CGI_URL_QUERYSTRING = $Template::CGI_URL . "?".$QUERY_STRING;
if ($QUERY_STRING ne "") { $Template::CGI_URL_QUERYSTRING .= "&"; }
$Template::QUERY_STRING = $QUERY_STRING;
$Template::CGI_HIDDEN_FIELDS .= "<INPUT TYPE=\"hidden\" NAME=\"QUERY_STRING\" VALUE=\"$FORM_QUERY\">";
$Template::ADMIN_CGI_URL = $AdminConfig->get("calendar_admin_url");
# Attempt to Login?
if ($in{'command'} eq "login") {
unless(&handleCustomFunction("display_before_login")) {
$User = new User($in{username}, $users_db, $permissions_db);
my ($result) = $User->login($in{password});
if ($result == 1) {
# User logged in
$Session->{'username'} = $User->{'username'};
$Session->{'name'} = $User->{'name'};
$Session->{'calendar'} = $calendar;
&addUserMessage(($User->{'name'} || $User->{'username'}) . $User::MSG_LOGGED_IN_SUCCESSFULLY);
elsif ($result == 2) {
undef $Session;
&addUserMessage(&getMessage("CALENDAR_PASSWORD_MUST_BE_CHANGED"));
&showSameScreen();
else {
&addUserMessage($User->getErrorMessage());
&showSameScreen();
&handleCustomFunction("display_after_login");
# Handle Logout
if ($in{'command'} eq "logout") {
unless(&handleCustomFunction("display_before_logout")) {
$Session->ExpireNow();
$Session->cleanupExpiredSessions();
undef $Session;
undef $Template::Session;
undef $User;
&handleCustomFunction("display_after_logout");
# Create a global "User" object if it doesn't already exist
unless(&handleCustomFunction("display_before_create_user")) {
unless ($User) {
if ($Session && ($Session->{'username'} ne "")) {
$User = new User($Session->{'username'}, $users_db, $permissions_db);
$User->{'logged_in'} = 1;
else {
$User = new User('anonymous', $users_db, $permissions_db);
$User->{'logged_in'} = 0;
$Template::User = $User;
&handleCustomFunction("display_after_create_user");
# Require Login?
if ($Config->get("require_login")) {
unless(&handleCustomFunction("display_before_require_login")) {
if ($Session->{'username'}) {
unless ($User->hasPermission($calendar,"VIEW")) {
$Template::userMessage = &getMessage("CALENDAR_NO_VIEW_PERMISSION");
&FATALERROR("");
else {
$in{'template'} = "login.html";
&showScreen();
&handleCustomFunction("display_after_require_login");
# Create the event and schedule database objects
$DBEvents = new DBFile($events_db);
$DBSchedule = new DBFile($schedule_db);
# Handle any commands here
# SEARCH
if ($in{'command'} eq "search") {
unless(&handleCustomFunction("display_before_search")) {
my ($properties,$name,$field);
foreach $name (keys %in) {
$field = $name;
if (($in{$name} ne "") && ($field =~ s/^FIELD_//)) {
$properties->{$field} = $in{$name};
if (scalar keys %$properties <= 0) {
&addUserMessage("Search query must not be blank!");
else {
$start = Time::Local::timegm(0,0,0,$in{start_date},$in{start_month}-1,$in{start_year});
$end = Time::Local::timegm(0,0,0,$in{end_date},$in{end_month}-1,$in{end_year});
$Template::SEARCH_RESULTS = &Event::search($DBEvents, $DBSchedule, "", $properties, $start, $end);
&handleCustomFunction("display_after_search");
&showScreen();
END {
if (defined $main::Session && ref($main::Session) eq "CGISession") {
$main::Session->saveSession();
# Populate variables and references for templates
sub populateTemplateVariables {
$localtime_offset = 3600*$Config->get("time_zone_offset");
($now_ss,$now_mi,$now_hh,$now_dd,$now_mm,$now_yy,$now_wd,$now_yd,$now_dst) = localtime(time+$localtime_offset);
$now_mm++;
$now_yy += 1900;
# Get the displayed dates, etc
$year = substr($in{'datestring'},0,4) || $in{'year'} || substr($in{'selected_datestring'},0,4) || $now_yy;
$month = substr($in{'datestring'},4,2) || $in{'month'} || substr($in{'selected_datestring'},4,2) || $now_mm;
$date = substr($in{'datestring'},6,2) || $in{'date'} || substr($in{'selected_datestring'},6,2) || $now_dd;
# Get selected date
$selected_datestring = $in{'selected_datestring'} || $year.&LZ($now_mm).&LZ($now_dd);
# Date-related fields and HTML elements
$Template::YEAR_SELECT = "<SELECT NAME=\"year\">" . &HTML::yearOptions($year) ."</SELECT>";
$Template::MONTH_SELECT = "<SELECT NAME=\"month\">" . &HTML::monthNameOptions($month) . "</SELECT>";
$Template::MONTH_ABBREVIATION_SELECT = "<SELECT NAME=\"month\">" . &HTML::monthAbbreviationOptions($month) . "</SELECT>";
$Template::DAY_NAMES = $Config->get("day_names");
$Template::DAY_ABBREVIATIONS = $Config->get("day_abbreviations");
$Template::MONTH_NAMES = $Config->get("month_names");
$Template::MONTH_ABBREVIATIONS = $Config->get("month_abbreviations");
for ($i=0; $i<7; $i++) { ${"Template::DAY_NAME_".$i} = $Template::DAY_NAMES->[$i]; }
for ($i=0; $i<12; $i++) { ${"Template::MONTH_NAME_".$i} = $Template::MONTH_NAMES->[$i]; }
for ($i=0; $i<7; $i++) { ${"Template::DAY_ABBREVIATION_".$i} = $Template::DAY_ABBREVIATIONS->[$i]; }
for ($i=0; $i<12; $i++) { ${"Template::MONTH_ABBREVIATION_".$i} = $Template::MONTH_ABBREVIATIONS->[$i]; }
$Template::MONTH_NAME = $Template::MONTH_NAMES->[$month-1];
$Template::YEAR = $year;
$Template::MONTH = $month;
$Template::DATE = $date;
$Template::DATESTRING = $year . &LZ($month) . &LZ($date);
$Template::NEXT_YEAR = $year+1;
$Template::LAST_YEAR = $year-1;
($Template::NEXT_MONTH_YEAR,$Template::NEXT_MONTH) = &Date::getNextMonthYear($year,$month);
$Template::NEXT_MONTH_NAME = $Template::MONTH_NAMES->[$Template::NEXT_MONTH-1];
($Template::LAST_MONTH_YEAR,$Template::LAST_MONTH) = &Date::getLastMonthYear($year,$month);
$Template::LAST_MONTH_NAME = $Template::MONTH_NAMES->[$Template::LAST_MONTH-1];
($Template::LAST_WEEK_YEAR,$Template::LAST_WEEK_MONTH,$Template::LAST_WEEK_DATE) = &Date::getLastWeek($year,$month,$date);
($Template::NEXT_WEEK_YEAR,$Template::NEXT_WEEK_MONTH,$Template::NEXT_WEEK_DATE) = &Date::getNextWeek($year,$month,$date);
($Template::NEXT_DAY_YEAR,$Template::NEXT_DAY_MONTH,$Template::NEXT_DAY_DATE) = &Date::getTomorrow($year,$month,$date);
$Template::NEXT_DAY_DATESTRING = $Template::NEXT_DAY_YEAR . &LZ($Template::NEXT_DAY_MONTH) . &LZ($Template::NEXT_DAY_DATE);
($Template::PREVIOUS_DAY_YEAR,$Template::PREVIOUS_DAY_MONTH,$Template::PREVIOUS_DAY_DATE) = &Date::getYesterday($year,$month,$date);
$Template::PREVIOUS_DAY_DATESTRING = $Template::PREVIOUS_DAY_YEAR . &LZ($Template::PREVIOUS_DAY_MONTH) . &LZ($Template::PREVIOUS_DAY_DATE);
($Template::TODAY_YEAR,$Template::TODAY_MONTH,$Template::TODAY_DATE) = ($now_yy,$now_mm,$now_dd);
$Template::TODAY_DATESTRING = $Template::TODAY_YEAR . &LZ($Template::TODAY_MONTH) . &LZ($Template::TODAY_DATE);
# Other
$Template::CALENDAR = $Calendar;
$Template::CALENDAR_KEY = $Calendar->{'key'};
# Call-back method to get events
*Template::getEvents = \&getEvents;
*Template::getEvent = \&getEvent;
# Method to get template preferences
*Template::getPreference = \&getTemplatePreference;
# Form input
%Template::in = %in;
# Looping and conditional special tags
&ASPCustomTag('\s*FOREACH\s*GRID\s*ROW\s*','foreach $ROW (0 .. $Grid->{rowcount}-1) {');
&ASPCustomTag('\s*FOREACH\s*GRID\s*COLUMN\s*','foreach $COL (0 .. $Grid->{colcount}-1) { $DAY = $Grid->{grid}->[$ROW]->[$COL]; my ($EVENTS) = $Grid->{grid}->[$ROW]->[$COL]->{events};');
&ASPCustomTag('\s*FOREACH\s*DAY\s*OF\s*WEEK\s*','foreach $COL (0 .. $Grid->{colcount}-1) { $DAY = $Grid->{grid}->[0]->[$COL]; my ($EVENTS) = $Grid->{grid}->[0]->[$COL]->{events};');
&ASPCustomTag('\s*FOREACH\s*HOUR\s*OF\s*DAY\s*','foreach $HOUR ( 99, $Config->{days_hours_display_start} .. $Config->{days_hours_display_end} ) { my ($EVENTS) = $DAY->{hours}->[$HOUR]->{events};');
&ASPCustomTag('\s*FOREACH\s*EVENTLIST','foreach $datestring (sort keys %$EventList) { $DAY = $EventList->{$datestring}; my ($EVENTS) = $DAY->{events};');
&ASPCustomTag('\s*FOREACH\s*EVENT\s*','foreach $EVENT (@$EVENTS) { ');
&ASPCustomTag('\s*FOREACH\s*SEARCH\s*RESULT\s*','foreach $i (0 .. $#$SEARCH_RESULTS) { $EVENT = $SEARCH_RESULTS->[$i]; ');
&ASPCustomTag('\s*IF\s*SEARCH\s*RESULT\s*','if ($in{command} eq "search") {');
&ASPCustomTag('\s*IF\s*SEARCH\s*RESULTS\s*EXIST\s*','if ($#$SEARCH_RESULTS < 0) {');
&ASPCustomTag('\s*IF\s*EVENTS\s*EXIST\s*','if ($#{$EVENTS} >= 0) {');
&ASPCustomTag('\s*IF\s*NEXT\s*OCCURRENCE\s*EXISTS\s*','if ($EVENT->{schedule}->{nextoccurrence}) {');
&ASPCustomTag('\s*IF\s*NO\s*EVENTS\s*EXIST\s*','if (!($#{$EVENTS} >= 0)) {');
&ASPCustomTag('\s*IF\s*DISPLAY\s*','if ($DAY->{\'display\'}) {');
&ASPCustomTag('\s*IF\s*SELECTED\s*','if ($DAY->{\'selected\'}) {');
&ASPCustomTag('\s*IF\s*USER\s*LOGGED\s*IN\s*','if ($User->{username} ne "anonymous") {');
&ASPCustomTag('\s*/FOREACH\s*','}');
&ASPCustomTag('\s*ELSE\s*','}else{');
&ASPCustomTag('\s*/IF\s*','}');
# Other special tags
&ASPCustomTag('=?\s*EVENT\s*FIELD\s*\((\w+)\)\s*','= $EVENT->{details}->{$1} ');
&ASPCustomTag('=?\s*SCHEDULE\s*FIELD\s*\((\w+)\)\s*','= $EVENT->{schedule}->{$1} ');
&ASPCustomTag('=?\s*PREFERENCE\s*\((\w+)\)\s*','= &getPreference(\'$1\') ');
&ASPCustomTag('\s*LAST\s*YEAR\s*LINK\s*','= $CGI_URL_QUERYSTRING."year=".$LAST_YEAR');
&ASPCustomTag('\s*NEXT\s*YEAR\s*LINK\s*','= $CGI_URL_QUERYSTRING."year=".$NEXT_YEAR');
&ASPCustomTag('\s*LAST\s*MONTH\s*LINK\s*','= $CGI_URL_QUERYSTRING."year=".$LAST_MONTH_YEAR."&month=".$LAST_MONTH');
&ASPCustomTag('\s*NEXT\s*MONTH\s*LINK\s*','= $CGI_URL_QUERYSTRING."year=".$NEXT_MONTH_YEAR."&month=".$NEXT_MONTH');
&ASPCustomTag('\s*LAST\s*WEEK\s*LINK\s*','= $CGI_URL_QUERYSTRING."year=".$LAST_WEEK_YEAR."&month=".$LAST_WEEK_MONTH."&date=".$LAST_WEEK_DATE');
&ASPCustomTag('\s*NEXT\s*WEEK\s*LINK\s*','= $CGI_URL_QUERYSTRING."year=".$NEXT_WEEK_YEAR."&month=".$NEXT_WEEK_MONTH."&date=".$NEXT_WEEK_DATE');
&ASPCustomTag('\s*PREVIOUS\s*DAY\s*LINK\s*','= $CGI_URL_QUERYSTRING."datestring=".$PREVIOUS_DAY_DATESTRING."&selected_datestring=".$PREVIOUS_DAY_DATESTRING');
&ASPCustomTag('\s*NEXT\s*DAY\s*LINK\s*','= $CGI_URL_QUERYSTRING."datestring=".$NEXT_DAY_DATESTRING."&selected_datestring=".$NEXT_DAY_DATESTRING');
&ASPCustomTag('\s*CALENDAR\s*NAME\s*','= ($CALENDAR->{name})');
&ASPCustomTag('\s*CALENDAR\s*DESCRIPTION\s*','= ($CALENDAR->{description})');
&ASPCustomTag('\s*CALENDAR\s*KEY\s*','= ($CALENDAR->{key})');
# Subroutine called by Template to get an event
sub getEvent {
my ($id) = @_;
unless(&handleCustomFunction("display_before_getEvent",$id)) {
my ($db) = new DBFile($events_db);
my ($event) = $db->getRecord( {'id'=>$id } );
if ($event == 0) { return {}; }
# Add the auto-links if necessary
if ($Config->get("auto_link")) {
foreach $key (keys %$event) {
$event->{$key} = &HTML::autoLink($event->{$key},$Config->get("auto_link_target"));
&handleCustomFunction("display_after_getEvent");
return $event;
# Subroutine called by Template to populate events
sub getEvents {
my ($properties) = @_;
unless(&handleCustomFunction("display_before_getEvents",$properties)) {
my ($event_ids,$events,$event_details,$s);
my ($month,$year,$date,$datestring,$start,$end);
$month = &LZ($properties->{'month'}) || &LZ($Template::MONTH);
$year = $properties->{'year'} || ($Template::YEAR);
$date = &LZ($properties->{'date'}) || &LZ($Template::DATE);
if ($properties->{'range'} eq "month") {
$datestring = $year . $month . "01";
$properties->{'startdate'} = $datestring;
else {
$datestring = $year . $month . $date;
$properties->{'startdate'} ||= $datestring;
($start,$end) = &Date::getTimeSpan( $properties );
$Template::RANGE_START = &SimpleDateFormat::formatDate($start,$Config->get("date_format"));
($Template::RANGE_START_DATE,$Template::RANGE_START_MONTH,$Template::RANGE_START_YEAR) = (gmtime($start))[3,4,5];
$Template::RANGE_START_MONTH++;
$Template::RANGE_START_YEAR+=1900;
$Template::RANGE_END = &SimpleDateFormat::formatDate($end,$Config->get("date_format"));
($Template::RANGE_END_DATE,$Template::RANGE_END_MONTH,$Template::RANGE_END_YEAR) = (gmtime($end))[3,4,5];
$Template::RANGE_END_MONTH++;
$Template::RANGE_END_YEAR+=1900;
$schedule = &Event::getEventsInRange($DBSchedule,$start,$end);
foreach $s (@$schedule) {
$event_ids->{$s->{'event_id'}}=1;
$event_details = &Event::getEventDetails($DBEvents,$event_ids);
# Skip the event unless it's approved
next unless ($event_details->{$s->{'event_id'}}->{'approved'});
# Skip if it's private
next if ($event_details->{$s->{'event_id'}}->{'private'});
push(@$events, { 'schedule'=>$s, 'details'=>$event_details->{$s->{'event_id'}} } );
# Put the raw events into the template
$Template::EVENTS = $events;
my ($Grid);
my ($start_ss,$start_mi,$start_hh,$start_dd,$start_mm,$start_yy,$start_wd,$start_yd,$start_dst) = gmtime($start);
$week_start_day = $Config->get("week_start_day");
if ($start_wd >= $week_start_day) {
$offset_days = $start_wd - $week_start_day;
elsif ($start_wd < $week_start_day) {
$offset_days = 7-$week_start_day+$start_wd;
$i = $start;
my $x = 0;
my $y = 0;
# Place pre-empty grid cells if more than one row
if ((($end - $start)/86400) > 7) {
foreach (0 .. ($offset_days-1)) {
$Grid->{'grid'}->[$y]->[$x]->{'display'} = 0;
$x++;
while ($i < $end) {
my ($ss,$mi,$hh,$dd,$mm,$yy,$wd,$yd,$dst) = gmtime($i);
my ($datestring) = (1900+$yy) . &LZ($mm+1) . &LZ($dd);
$gridMappings->{$datestring} = [$y,$x];
$Grid->{'grid'}->[$y]->[$x]->{'dd'} = $dd;
$Grid->{'grid'}->[$y]->[$x]->{'mm'} = $mm+1;
$Grid->{'grid'}->[$y]->[$x]->{'yyyy'} = 1900+$yy;
$Grid->{'grid'}->[$y]->[$x]->{'wd'} = $wd;
$Grid->{'grid'}->[$y]->[$x]->{'yd'} = $yd;
$Grid->{'daynames'}->[$x] = $Template::DAY_NAMES->[$wd];
$Grid->{'grid'}->[$y]->[$x]->{'dayname'} = $Template::DAY_NAMES->[$wd];
$Grid->{'grid'}->[$y]->[$x]->{'dayabbreviation'} = $Template::DAY_ABBREVIATIONS->[$wd];
$Grid->{'grid'}->[$y]->[$x]->{'monthname'} = $Template::MONTH_NAMES->[$mm];
$Grid->{'grid'}->[$y]->[$x]->{'monthabbreviation'} = $Template::MONTH_ABBREVIATIONS->[$mm];
$Grid->{'grid'}->[$y]->[$x]->{'datestring'} = $datestring;
$Grid->{'grid'}->[$y]->[$x]->{'display'} = 1;
if ($datestring eq $selected_datestring) {
$Grid->{'grid'}->[$y]->[$x]->{'selected'} = 1;
$x++;
$Grid->{'rowcount'} = $y+1;
if ($x > $Grid->{'colcount'}) { $Grid->{'colcount'} = $x; }
if ($x > 6) { $x=0; $y++; }
$i+=86400;
# Place post-empty grid cells if more than one row
while($wd < 6) {
$x++;
$wd++;
$Template::Grid = $Grid;
$Template::GRID_ROW_COUNT = $Grid->{'rowcount'};
$Template::GRID_COLUMN_COUNT = $Grid->{'colcount'};
# Map events on to Grid and dates/hours/etc
foreach $event (sort {$a->{'schedule'}->{'start'} <=> $b->{'schedule'}->{'start'} } @$events) {
# Time of event
if ($event->{'schedule'}->{'start_time'} == $event->{'schedule'}->{'end_time'}) {
$event->{'schedule'}->{'end_time'} = "";
if ($event->{'schedule'}->{'all_day'}) {
$event->{'schedule'}->{'start_time'} = "";
$event->{'schedule'}->{'start_hh'}=99;
$event->{'schedule'}->{'start_mm'}=0;
$event->{'schedule'}->{'end_hh'}=99;
$event->{'schedule'}->{'end_mm'}=0;
else {
($hh,$mm) = ($event->{'schedule'}->{'start_time'} =~ /^(\d\d)(\d\d)/);
$event->{'schedule'}->{'start_hh'} = $hh;
$event->{'schedule'}->{'start_mm'} = $mm;
($hh,$mm) = ($event->{'schedule'}->{'end_time'} =~ /^(\d\d)(\d\d)/);
$event->{'schedule'}->{'end_hh'} = $hh;
$event->{'schedule'}->{'end_mm'} = $mm;
$event->{'schedule'}->{'start_time'} = &Date::formatTime($event->{'schedule'}->{'start_time'}, $Config->get("time_format"));
$event->{'schedule'}->{'end_time'} = &Date::formatTime($event->{'schedule'}->{'end_time'} , $Config->get("time_format"));
# Date, month, day name, month name, etc
my ($event_start) = $event->{'schedule'}->{'start'};
my ($event_end) = $event->{'schedule'}->{'end'};
my ($continued) = 0;
# If event spans multiple days, keep track of it
$event->{'schedule'}->{'span'} = (($event_end - $event_start) > 86400)?1:0;
while ($event_start <= $event_end) {
if (($event_start >= $start) && ($event_start <= $end)) {
my ($ss,$mi,$hh,$dd,$mm,$yy,$wd,$yd,$dst) = gmtime($event_start);
$event->{'schedule'}->{'year'} = (1900+$yy);
$event->{'schedule'}->{'month'} = $mm+1;
$event->{'schedule'}->{'date'} = $dd;
$event->{'schedule'}->{'day'} = $wd;
$event->{'schedule'}->{'datestring'} = $datestring;
$hh = 99;
else {
$hh = &LZ($hh);
push(@{$Grid->{'grid'}->[$gridMappings->{$datestring}->[0]]->[$gridMappings->{$datestring}->[1]]->{'events'}} , $event);
push(@{$Grid->{'grid'}->[$gridMappings->{$datestring}->[0]]->[$gridMappings->{$datestring}->[1]]->{'hours'}->[$hh]->{'events'}} , $event);
$continued=1;
$event_start = $event_start+86400;
# Sort the events on each day into chronological order
for ($y=0; $y<$Grid->{'rowcount'}; $y++) {
for ($x=0; $x<$Grid->{'colcount'}; $x++) {
if ($Grid->{'grid'}->[$y]->[$x]->{'display'}) {
@{$Grid->{'grid'}->[$y]->[$x]->{'events'}} = sort { ($a->{'schedule'}->{'start'} <=> $b->{'schedule'}->{'start'}) || ($a->{'details'}->{'id'} <=> $b->{'details'}->{'id'}) } @{$Grid->{'grid'}->[$y]->[$x]->{'events'}};
$EventList->{$Grid->{'grid'}->[$y]->[$x]->{'datestring'}} = $Grid->{'grid'}->[$y]->[$x];
$Template::EventList = $EventList;
if ($properties->{'range'} eq "day") {
$Template::DAY = $Grid->{'grid'}->[0]->[0];
$Template::EVENTS = $Grid->{'grid'}->[0]->[0]->{'events'};
&handleCustomFunction("display_after_getEvents",$properties);
Simon
Have you given any thought about using one of those Freebie Calendars where there is not any script involved.
I was thinking of using one on a site for a fishing club and it works good, the calendar can also be interactive by the club's members by using a password.
There are not any banners or advertisements.
You can see the calendar page here, http://rjskon.com/carl/calendar.htm
Richard
Hi everyone.
Simon, I don't know much about PERL myself but shouldn't the first line of the script have "#!/usr/bin/perl" instead of just "!/usr/bin/perl" (note the # at the beginning)?
Raul is right.
Hello guys and thanks for your help
Borfast,
I though that # was the first line of a comment so you had to take it out. (That shows that I am not a PERL guru either :dance: )
Richard,
thanks for your suggestion of the freebie script. Yours is great, where did you get it ?
Also I have been using their documentation page. I have also been using their support forum. I did not look at it for a few days.NOw I am ready to start again...unless I find the source of your freebie calendar :dance:
Simon
Simon
That Freebie Calendar can be found http://www.calendars.net
It is not a script, you use calendar.net severs to host your calendar.
It's free, there are not any banners, pop ups or junk mail, I don't know how they do it for free, they also have a paid version.
I have that Calendar open in the body of one of the pages of that Fishing Clubs site, the top frame resembles the rest of the pages.
Good luck
Richard
