makaveli Posted October 23, 2006 Share Posted October 23, 2006 Today i added some new albums, "My music" > Right Click > add to media library and when i disconnected and walked out the door, it said "re building media libray" its done this before, so i thought "ah so what" but... it kept going, and going and going and froze at 80% so i left it, and left it, went to work, came back and it was off, so i was like "oooh great its booted and auto shut down" but what has happened is it wont switch on! it wont charge! its a useless brick now? looked round the net and cant find details of how to hard reset it or if there is a way to fix it i love my music any ideas folks? advanced massive thanks if you can help! Quote Link to comment Share on other sites More sharing options...
TCH-Andy Posted October 23, 2006 Share Posted October 23, 2006 What machine is it ? laptop? Desktop? Palm? What happens when you try and turn it on? Quote Link to comment Share on other sites More sharing options...
TCH-JimE Posted October 23, 2006 Share Posted October 23, 2006 Have you tried looking through the technical help on the creative website? JimE Quote Link to comment Share on other sites More sharing options...
makaveli Posted October 23, 2006 Author Share Posted October 23, 2006 yep, and as with all tech support from the vendors its rubbish to say the least, it wont power on, so remove the battery and try again, er yeah. i've tried emailing tech support, but again i dont hold out hope. Quote Link to comment Share on other sites More sharing options...
TCH-Andy Posted October 23, 2006 Share Posted October 23, 2006 I missed the title from a quick google, it seems the Creative Zen should have a hole where you can insert a paperclip (or similar) to do the reset. Depending on the model, you may need to press the play / pause button or the power button at the same time. Quote Link to comment Share on other sites More sharing options...
makaveli Posted October 23, 2006 Author Share Posted October 23, 2006 (edited) apparently they dont, only flash disk players have reset holes, hard drive ones you have to remove the battery, then put it in while holding on switch, a menu will come up.... not much use if you cant power it up Edited October 23, 2006 by makaveli Quote Link to comment Share on other sites More sharing options...
TCH-JimE Posted October 23, 2006 Share Posted October 23, 2006 I hate to be the bringer of bad news, but having googled this problem, it would seem a very common one. Is it still under warantee? JimE Quote Link to comment Share on other sites More sharing options...
makaveli Posted October 23, 2006 Author Share Posted October 23, 2006 yep, i have the care plan, i ripped dixons of and got it for about 75% less. only problem, i dont have "all the bits" or the box, and not sure where my reciept is. the major one is not having "all the bits" as they;l want it all, cables, books, cd's headphones... Quote Link to comment Share on other sites More sharing options...
makaveli Posted October 28, 2006 Author Share Posted October 28, 2006 problem over, with creative use of words (no pun intended) i upgraded to a 30gb video zen Quote Link to comment Share on other sites More sharing options...
