I'm doing a redesign of my website, gale2006.com. For some strange reason I'm having a terrible time getting the borders to work how I want them to.
The new website design will be www.gale2006.com/new2.htm When pulling up the site in Internet Explorer, it works great... exactly how I want it to. But when I pull it up in Mozilla Firefox, the borders are back and the links are underlined. Any ideas how I can fix these problems? While you're at it... any thoughts about the basic new design?
Thanks! You all are always so helpful.
Eric
Hmm... well I really know nothing about CSS. I know only a limited amount about HTML. Can anyone explain where I would need to change the code?
Thank you
Run it through the validation page and it will give you the line numbers of the error and what's wrong. FWIW...you'll have an easier time getting your site to show properly in most browsers if you try to adhere as much as possible to HTML or XHTML standards. As has been brought up numerous times before in other threads, IE doesn't stick to established standards.
For overall style issues like this, it really is worth getting a basic understanding of CSS. You could put it on every tag without any knowledge but learning just a tiny bit will make it so much easier - you can tell it to do every link, for instance, with one line.
