boxturt Posted June 8, 2003 Posted June 8, 2003 I've just installed and indexed my site with iSearch and I would like to automatically index the site once weekly. The script suggests using a cron job and suggests the following command line syntax : /usr/bin/php -q /home/user/public_html/isearch/admin/reindex.php Is this correct and or allowed? Thanks, -Ty Quote
TCH-Rick Posted June 8, 2003 Posted June 8, 2003 Thanks for the link. I installed the iSearch program and set up a test crontab and it worked fine just as you have it. Setting it up to run weekly should be no problem. Let us know how it works. Quote
boxturt Posted June 8, 2003 Author Posted June 8, 2003 Thank you Rick. I'll certainly let you know how it goes -ty Quote
KevinW Posted June 8, 2003 Posted June 8, 2003 Ty, I've add a link about iSearch to the TCH Help web site - click here -kw Quote
boxturt Posted June 8, 2003 Author Posted June 8, 2003 Cool. It seems to work very well. I put up my own test page HERE . If you follow a search result to an actual song file you'll have to 'back-button' out as the navigation doesn't work in this scenario. -Ty Quote
boxturt Posted June 9, 2003 Author Posted June 9, 2003 Hmmm, I set it to run crontab last night (using line from first post) and it seems not to have worked. I imagine I was to receive an email? Settings were : * 3 1 * * That's 3am every Monday, right? That directory is protected, at the insistance of the script. Is that why the crontab didn't run? Thanks -ty And on a side note - when I manually indexed the site it came up about 2000 records short. Maybe I just haven't configured it correctly. Blea. Head Bash Quote
boxturt Posted June 12, 2003 Author Posted June 12, 2003 I hate to ask again... The admin directory is protected, at the insistance of the script. Is that why the crontab didn't run? Thanks, ty Quote
surefire Posted June 12, 2003 Posted June 12, 2003 Boxturt, since I'm rather new to cron (old hosting company didn't allow) I can't say for sure... but here's how I would trouble shoot: I'd put a simple php script in the same director that does nothing but send you an email. Then I'd set up a new cron directive set to execute the script every other minute. This should give you some indication if your idea is going to work (and I think it will). Also, it looks like you are setting up a cron job with the 'advanced' option (writing it by hand). Have you considered setting it up by using the 'basic' cpanel interface? Quote
boxturt Posted June 12, 2003 Author Posted June 12, 2003 (edited) That is of course a very good suggestion. I'm a little embarassed to say I wouldn't know a simple php mail script if it jumped out and bit my nose. I'll see what I can figure out Thank you. Ok, i was able to get something with a javascript. Got the following: /bin/sh: /home/lyricsp/public_html/isearch/admin/crontest.html: Permission denied Guess that means I can't run cron in a protected folder? Edited June 12, 2003 by boxturt Quote
surefire Posted June 12, 2003 Posted June 12, 2003 Doesn't have to be PHP... as you probably figured out. But here's what I'd write test.php <?phpmail("you@******", "Test subject", "This is a test message for cron job test.", "From: Your Website"); ?> Quote
boxturt Posted June 12, 2003 Author Posted June 12, 2003 Thank you Jack for the suggestion and the snippet. That did work, I received the emails. So I have set up a cron job to index the site for 3am - using the standard setting. I'll let you know! Thanks. Quote
boxturt Posted June 14, 2003 Author Posted June 14, 2003 Well, here's the 'letting you know' part. Something happened when the job ran but I think it stopped. Here's what cron-daemon mailed me: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"><html lang="en"> <HEAD> <TITLE>iSearch Reindex Site</TITLE> <META HTTP-EQUIV="Content-Type" content="text/html; charset=utf-8"> <META HTTP-EQUIV="Content-Language" CONTENT="EN-GB"> <META HTTP-EQUIV="Pragma" content="no-cache"> <META HTTP-EQUIV="Expires" content="Fri, 01 Jan 1999 00:00:01 GMT"> <META NAME="author" CONTENT="Ian Willis"> <META NAME="copyright" CONTENT="Copyright Ian Willis. All rights reserved."> <META NAME="robots" CONTENT="noindex,nofollow"> </HEAD> <BODY BGCOLOR="#ffffc0" TEXT="#000000"> <H1>iSearch Reindex Site</H1> <H3>Spidering Starting Now...</H3>Processing URL [http://lyricsplayground.com/]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestecritsurlesmurs.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestenfrance.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/top_frame.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestenseptembre.html]<BR> Processing URL [http://lyricsplayground.com/home.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestextra.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestfatal.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestfini.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestfinimissmolly.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlaouate.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlavie.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlaviequiveutca.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlamour.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlamouretlaviequejetedois.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlemashedpotatoes.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestleprintemps.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlerefraindemavie.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlereggae.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestlointoutca.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestluiquemoncoeurachoisi.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestluiquidort.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestmachanson.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestmavie.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestmerveilleux.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestmerveilleuxlamour.html]<BR> URL not changed since last spidering [http://lyricsplayground.com/alpha/songs/c/cestmieuxainsi.html]<BR> Processing URL [http://lyricsplayground.com/guestbook/]<BR> </BODY> <HEAD> <META HTTP-EQUIV="REFRESH" CONTENT="1;URL=?reset=false"></HEAD></HTML> Checking the number of files indexed I see it hasn't changed and if it had run all the way the number reflected would certainly be different. (that "refresh" tag bugs me a bit and I don't know where it came from.) Any thoughts? This is driving me nuts Head Bash Quote
surefire Posted June 14, 2003 Posted June 14, 2003 I wish I had direct experience with this script... but I don't. You might want to consider PM to those in this thread that seem to have used it successfully. On another note, it appears that the cron is working... so maybe your issue is with the script. To troubleshoot, I would change one of these files and see what happens the next go-round. Quote
boxturt Posted June 14, 2003 Author Posted June 14, 2003 I guess all I can do is keep tinkering. I really don't know why it stopped after that handful of files. I have indexed manually and it was more or less correctso it shouldn't have anything to do with number of files either (+16,500). If I get an invitation to PM someone I will * wink*wink*nudge*nudge* Thanks Quote
idallen Posted June 15, 2003 Posted June 15, 2003 I really don't know why it stopped after that handful of files. Some TCH servers run an automatic script every 5 minutes that kills jobs that take more than a certain amount of CPU time. You can ask the sysadmin team to have the indexing script be exempted from the automated kill function. (This has been done on server20.) If you're lucky with your timing, you can start your indexing script just after the last process kill script ran, and this gives you five uninterrupted minutes to get your site indexed before the next time processkill runs. Maybe you can get it done in that time... Quote
boxturt Posted June 15, 2003 Author Posted June 15, 2003 Thanks Ian. That's something to look into and I suspect you may be correct. It did the same thing last night too. Quote
