Your stylesheet include should look like this :
><link rel="stylesheet" type="text/css" href="..." media="print" />
in place of the href i put the place where the css file is, correct?
I did this, and it doesnt work. The web page is all disconfigured.
Edited by antandsons
Yep, it should look like :
><link rel="stylesheet" href="http://www.antandsons.com/style.css" type="text/css" media="print" />
And you need to replace that bit of code on your pages with the code above, yup.
Edited by marie b.
It looks exactly the same here.
Have you copied the above code exactly, and linked to the CSS file properly? I just copied the code as I have it on my site and substituted your link for mine, so it should work.
You don't need to alter the CSS file at all.
That link should work, as your webpage looks exactly the same as it did before for me.
Try deleting the <style type="text/css"> and </style> tags from your CSS file.
They don't belong there.
Also delete the commenting around the body field in your CSS file.
Edited by marie b.
Try this :
><link rel="stylesheet" type="text/css" media="all" href="http://www.antandsons.com/style.css" />
It may be an issue with the order of elements within the link.
Changed the order of the elements. The page is back to normal, though the print layout is the same.
I am wondering maybe if there is another problem. For example, on some computer the content column (middle column with all the text) is really squeezed together, just like it is in the print preview screen. It's probably something with the style sheet that I have to fix. What do you think? Any suggestions?
It does seem odd that a two columned, left-aligned layout shrinks when i minimize my browser, even though I'm on a high resolution.
I do notice that the commenting around the "body" in your CSS file is still there. See if removing that helps with the printing issue? It should look like :
>body {
 margin-top: 10px;
 margin-right: 0px;
 margin-bottom: 2px;
 margin-left: 30px
not
body {
 margin-top: 10px;
 margin-right: 0px;
 margin-bottom: 2px;
 margin-left: 30px
Edited by marie b.
I removed the commenting and it made the body ineffective.
Good catch. I just started shrinking my browser and noticed that the text in the center column did move as I moved the browser. How can i fix this?
That would require altering the CSS.
I'd suggest looking at :
>#content {
      padding: 0px;
   padding-top: 0px;
      margin-top: 0px;
   margin-left: 150px;
      margin-right: 350px;
The right margin seems a big excessive.
Try changing 350px to 15%.
Please keep in mind that the print css file should be a different css file than your screen file.
Copy the screen file and save it as something like print.css
edit it and charge parts you do to want to print
to display: none;
here is an example
>/*  print.css file */
/* set page to white with black type */
body {
background-color: #FFFFFF;
color: black;
font-family: Times New Roman, Times, Serif;
font-size: 18px;
margin: 1em 1em 1em 1em;
/* turn off items not to print */
hr {
display: none;
table.banner {
display: none;
td.menu {
display: none;
td.content{
text-align: left;
div.main_right_float{
display: none;
td.footer{
display: none;
then link them both
><link type="text/css" rel="stylesheet" href="style.css" media="screen">
<link type="text/css" rel="stylesheet" href="print.css" media="print">
Now when you do a print preview it should look like it will when printed
and this requires no special action by the visitor.
hope this helps.
What if someone wants to copy the page as is, though? It makes sense to have the media specified in the one link, in that case.
It looked like the original question was to print the page with the TOS
There are many ways to handle printing with css.
Here are links to help
http://www.javascriptkit.com/dhtmltutors/cssmedia.shtml
http://www.w3.org/TR/REC-CSS2/media.html
http://www.alistapart.com/articles/goingtoprint/
Its just my opinion,
but most visitors that are going to print out something from a page
will only want the content
and not nav buttons, images or other common elements.
You can alway add the style to just one page for printout.
But thats up to you.
You can always leave off the media discriptor or set it to all.
I agree with this statement. Why waste the ink on something that will not be used as a reference?
Some people need to print pages as is for school assignments. :)
Edited by marie b.
