My old web host went bankrupt so I moved to TCH. I have my own CGI
counter script which worked fine on my old Linux/Apache host, but
it doesn't work here. I did CHMOD 755 on the script. The script
works fine on TCH as a cron job but not when called from a web page,
so the problem must be in the call. This call worked on my old host
but gives no output here:
<!--#exec cgi="cgi-bin/counter.cgi" -->
This also gives no output:
<!--#exec cgi="./cgi-bin/counter.cgi" -->
This gives an error message, "[an error occurred while processing
this directive]":
<!--#exec cgi="/cgi-bin/counter.cgi" -->
I'd appreciate any help.
Thanks,
Wayne
First of all, welcome to the family, Wayne Thumbs Up
Unfortunately, I don't know how to help you with this issue but we have many knowledgeable folks in the forums and I'm sure someone will drop by and help you out in no time :blink:
You haven't provided much information that would help in troubleshooting the problem. If you look in the Error Log in your CPanel there may be some messages there that can help. Also, if you can provide a url to the page so we can see where the error is occurring we might be able to see more.
:blink: Welcome to the Family Wayne :dance:
and your new home!
is the <!--#exec cgi="cgi-bin/counter.cgi" -->
in a page with the .shtml extension?
I know it mus be, but just double checking.
Or you can get a cgi counter in your cpanel > cgi scripts.
It may be close to what you had,
and can be styled and set to a starting number.
So if you need anything,
just ask your new family!
We love to help :)
Hi again,
Thanks for the warm welcome!
My files are all .htm. I added lines to .htaccess so .htm files would be
parsed for SSI. I put an include at the bottom of the file to prove to
myself that SSI is working.
Just for kicks, I copied my index.htm to index.shtml. Same error.
Cpanel Error Log excerpt:
[Mon Sep 13 19:15:41 2004] [error] [client 204.48.233.58] invalid CGI ref "/cgi-bin/counter.cgi" in /home/tpalsor/public_html/index.htm
[Mon Sep 13 19:14:26 2004] [error] [client 204.48.233.58] invalid CGI ref "/cgi-bin/counter.cgi" in /home/tpalsor/public_html/index.shtml
Pages are at:
http://66.36.231.135/~tpalsor/index.htm
http://66.36.231.135/~tpalsor/index.shtml
Ideas?
TIA,
Wayne
Hi Wayne.
Do you have a domain name? or are you just trying to get it working with the IP address?
If you are using the IP address, then it will just be cgi-bin or /home/tpalsor/public_html/cgi-bin not /cgi-bin
Some scripts etc will also not work until your domain name has propagated.
Glad you have it working!
For e-mail
did you set the options in My Controls for
e-mail settings
Enable 'Email Notification' by default?
Enabling this option will automatically subscribe you to any topic you start or reply to.
And in board setting you may want to set
Do you wish to get a pop up notification when you get a new private message? to YES
