alf__ Posted August 9, 2004 Posted August 9, 2004 Hello... I'm very happy with your cpanel and webspace, speed of servers,... But I have one question. Problem is when running some scripts that generate files and the script works long time. Default settings for setTimeout are 30 seconds. I was wondering if it would be possible to set this limit a bit higher (60 secs)? Than you... Quote
TCH-Bruce Posted August 9, 2004 Posted August 9, 2004 Welcome to the family, alf__ Don't know if that's possible and would be answered quickly by submitting a Help Desk ticket. Moving for organization. Quote
virtualstijn Posted August 13, 2004 Posted August 13, 2004 If you have the possibility to modify the php.ini -file. Do that and somewhere in there you can change the time-out-'length' Quote
TCH-Rob Posted August 13, 2004 Posted August 13, 2004 If you have the possibility to modify the php.ini -file. Do that and somewhere in there you can change the time-out-'length' Individual users cannot modify the php.ini file on shared servers. Quote
TCH-Don Posted August 13, 2004 Posted August 13, 2004 Welcome to the Family alf and your new home! We really are like family here. So if you need anything, just ask your new family! We love to help Quote
TCH-Rob Posted August 14, 2004 Posted August 14, 2004 Alf, Put this in your .htaccess file; php_value max_execution_time 300 It should give you a 300 second shot at getting your files uploaded. Quote
alf__ Posted August 14, 2004 Author Posted August 14, 2004 great! IT WORKS! Thanks for your answer, it helped me a lot Quote
TCH-Rob Posted August 15, 2004 Posted August 15, 2004 Glad to see you got it working. Welcome to the family Thumbs Up Quote
TCH-Rick Posted August 15, 2004 Posted August 15, 2004 Just a word of warning. The server settings are designed to prevent problems. If you set a longer timeout on the script and for some reason it goes into a loop and runs the whole time it could well cause server loads to climb and result in suspension of your site. Scripts go beserk sometimes. Quote
TCH-Rob Posted August 15, 2004 Posted August 15, 2004 I guess I should have added that if one modifies the defaults set by TCH and it causes bad things then it will have adverse effects on your account. We have set those defaults to protect against overloading the servers. With the script above if you "have" to use it then set it to the longest you need it for and if it is a one time thing then remove it after you are finished. Quote
TangentIdea Posted November 10, 2004 Posted November 10, 2004 Okay, I'm trying to do this, and it's not working. Whenver I put that line in my .htaccess file, the whole file won't work. I'm assuming I just missed something and I'm doing it wrong. What am I possibly missing? Here's the content of my .htaccess file: ErrorDocument 404 /404.htmlphp_value max_execution_time 300 -Ryan Quote
TCH-Thomas Posted November 10, 2004 Posted November 10, 2004 (edited) Welcome to your extended family alf Edited November 10, 2004 by TCH-Thomas Quote
section31 Posted November 10, 2004 Posted November 10, 2004 Alf, Put this in your .htaccess file; php_value max_execution_time 300 It should give you a 300 second shot at getting your files uploaded. interesting...does that actually work... So we are allowed to change the php ini settings through the .htaccess file but not through ini_set function? http://us2.php.net/manual/en/function.ini-set.php Quote
TCH-Rob Posted November 10, 2004 Posted November 10, 2004 interesting...does that actually work... So we are allowed to change the php ini settings through the .htaccess file but not through ini_set function? http://us2.php.net/manual/en/function.ini-set.php It should work. I dont recomend you change any of the settings if you dont need to. Keep in mind that overriding the default settings may cause issues. Quote
