Munnin Posted April 27, 2004 Posted April 27, 2004 Ok, I set up a series of e-mail boxes for a site. pop: mail.xigenics.net smtp: mail.xigenics.net He has tried both port 25 and port 26 and not had any luck sending mail but can recieve it. any advice? Quote
TCH-Dick Posted April 27, 2004 Posted April 27, 2004 try checking "my server requires authentication" in the account properties Also his ISP may not allow you to send mail through a server that isnt theirs, try using the ISP's SMTP server. Quote
Munnin Posted April 27, 2004 Author Posted April 27, 2004 OK I am no longer at work and so no longer behind a fire wall and can try this my self. I have tried setting the client to use regular SMTP pasword athunitication. using: mail.myserver.net on port 25 the connection times out. using: myserver.net on port 25 the connection times out. using: 69.50.193.27 on port 25 the connection times out. While I can use my providers SMTP server his provider does not supply one so I am sure it must be allowed for him. FIXED Needed to use port 26 and alter teh usename to use @ sign even though the plus sign worked fine with the pop server. Quote
