There are various ways to do that...
PHP (requires .php extension, and path is relative to location of page on the file system):
<?php
include("includedir/header.html");
Server Side Includes (require .shtml extension)
Virtual (path a browser uses to access file):
<!--#include virtual="/includedir/header.html"-->
Those are just a couple ways.
You can do a google search for php include or server side includes for more detail info. Or ask here.
Hope that helps.
Another option is to leave your files named .htm or .html and add the following lines to your .htaccess file which tells the server to check for PHP code even if the file does not end in .php
AddType application/x-httpd-php .htm
AddType application/x-httpd-php .html
