[=hris Posted January 30, 2004 Posted January 30, 2004 I have just got a TCH package, and want to put a temp. small flash movie on the home page of my site saying "coming soon" I created a page, uploaded it, and went to the site (http://www.chrisps.com/index.html) But it just doesnt load - it just says opening page. I stripped it down to the bear minimum code just to get the flash movie displayed, and it still didnt work - i put the exact same page on my computer's web server, and it works fine, and if goto http://www.chrisps.com/login.swf it also works fine. If i put an html file that just says "hello" it works fine, but it just doesnt want to load the html page that contains that swf Any ideas? Quote
TCH-Bruce Posted January 30, 2004 Posted January 30, 2004 I just tried your index page and it loaded fine. Quote
GroovyFish Posted January 30, 2004 Posted January 30, 2004 Chris, I see the flash using either of those links (using Mozilla). The index.html link shows the flash pretty small, the direct link to the swf shows it full size. HTH Quote
borfast Posted January 30, 2004 Posted January 30, 2004 Works fine here, too. Are you sure you have the Flash plugin installed on the browser you're using? Quote
[=hris Posted January 30, 2004 Author Posted January 30, 2004 Lol yes i do have flash installed - it loads from running on my local web server - it is probably microsoft being microsoft again!!! I will try it on another pc Thanks for looking guys Quote
TCH-Don Posted January 30, 2004 Posted January 30, 2004 I do not see it with the http://www.chrisps.com/index.html'>http://www.chrisps.com/index.html but it shows up fine for http://www.chrisps.com/ Quote
TCH-Don Posted January 31, 2004 Posted January 31, 2004 [=hris I am moving this to the Dreamweaver/Flash forums where you may get more help. Quote
cloudrm Posted January 31, 2004 Posted January 31, 2004 I have the same problem. . . http://www.chrisps.com/ works. http://www.chrisps.com/index.html doesn't work. I'd start by making sure the page has the /index.html, or /index.shtml extentson if it's going to be your homepage. $0.05 Quote
borfast Posted January 31, 2004 Posted January 31, 2004 http://www.chrisps.com/index.html is not there, the file is called index.php, not index.html... But it's strange, because I could swear that I clicked the link the first time and it worked... Anyway, http://www.chrisps.com/index.php works fine. Quote
The Wild One Posted January 31, 2004 Posted January 31, 2004 http://www.chrisps.com/ works fine for me. Remeber that all you need to do is go to your root of the site and it will find the index file. later Quote
