I am trying to install the Nucleus blogging system at my website and during the install sequence the following error message occurs when the program attempts to create a database:
Error message was: "Could not create database. Make sure you have the rights to do so. SQL error was: Access denied for user: 'mrsimmo@localhost' to database 'nucleus'";
Can you help?
Thanks!
Don Simmons
www.mrsimmons.net
I just went to Cpanel and created a database named "nucleus" but there was no place to set up a user/password. I then tried my install again and got this error message:
Error message was: "Could not connect to mySQL server: Access denied for user: 'dsimmo@localhost' (Using password: YES)";
Thanks in advance for help.
Don Simmons
charle97 beat me to it. But just to add to that, I'm not sure how you configure Nucleus but whether it is a web based config or you have to edit the config manually make sure the database name and username are formatted correctly
dbase name should be cpanelname_dbasename
username should be cpanelname_dbaseusername
