WAdotcom Posted November 5, 2003 Posted November 5, 2003 I made a file called "xalienabduction.php" which basically loads up a flash/shockwave game. After I put the HTML code on the php page and saved it, I went to edit it (this all took place in cPanel) and for some strange reason, cPanel keeps on adding this code to the bottom of the document: >Save file as: <input type=text value="xalienabduction.php" name=file> <br> <input type="submit" value="Save"> </form> </center></font></body> </html> <!---cPanel [8.5.3-STABLE_3] Copyright (c) 1997-2003 John N Koston. Licensed on server23.totalchoicehosting.com ---> ...and then the "save" button isn't there in the bottom. This is truly weird. Oh and if you're wondering, the reason I made it a PHP file rather than HTML is because I used some minor PHP code on that page to load up the header and footer HTML templates. Quote
TCH-JimE Posted November 5, 2003 Posted November 5, 2003 Hi, Odd, never seen that before! Start a help ticket and we shall try to get it removed for you. Its not harming your code because its edited out using <-- comands Jim Quote
TCH-Don Posted November 5, 2003 Posted November 5, 2003 One of our family members recommended an editor with built in ftp to open, edit and re-save a file on your site. Source Edit from www.brixoft.com I have found this easier to use than going through cpanel. Plus you can undo and re save. Thanks Anacrusis, great program! Quote
