Rosanne 0 Posted June 13, 2012 Share Posted June 13, 2012 I'm volunteer tech support for our church, and would like to migrate them from POP to IMAP. They (and I) use Thunderbird to access their accounts. Gmail autofills with the correct IMAP settings; could you either have a tutorial or an addition to an existing tutorial that gives TCH's correct settings? Is it just a matter of selecting IMAP and changing the ports? Thanks! ~ Rosanne Quote Link to post Share on other sites
TCH-Bala 17 Posted June 13, 2012 Share Posted June 13, 2012 Normally changing the configurations on your email client from POP to IMAP will do the trick, as the email client will auto fill the ports. If you are facing issues, we are here to help. Quote Link to post Share on other sites
