Hi All,
I am trying to install Wordpress. Followed the instructions I found on the forum, but I keep getting this...
My link
Then I get an email from TC saying that there was a request for a DNS change and it will take 24-48 hours, could this be the reason Wordpress cannot find the page? Any help is much appreciated.
Thanks,
MB
That is your user account on the server. These are automatically created when the account is added. It points to your public_html folder.
ok, i get it now, forgot that was my username. :)
I'm setting up another blog and thought I had this wordpress installation figured out but still won't work for me. This is the url I am using
My link
Any help would be appreciated.
Thanks!
MB
My link
Thanks!
MB
sorry i am actually using this link and still not working. have doubled checked db name, user name and password.
http://208.76.82.89/~xophuth/wp-admin/install.php
It sounds to me that either the database name, username or password is incorrect in the wp-config.php file.
Also, make sure a database has been created (and user added to the db) in cpanel with the same db name, username and password as entered in the above file.
Hi Thomas,
I agree it does sound that way, but I rechecked everything numerous times and it still would not work. I'll check it again tonight after work. Maybe I'll find the error after I've been away from it for a while.
Thanks,
MB
The error message I'm seeing is:
Error establishing a database connection
Sounds like the database does not exist or the user you are trying to access it as does not exist or has not been added to the it.
Sorry, I see a prefectly visible site there and no errors.
Has this domain been moved from somewhere else to TCH?
The DNS was changed yesterday afternoon, you are probably still seeing the old site.
I see the error that Bruce mentions now.
A whois also tells me that the nameservers are set to different hosts:
Name Server: DNS3.TOTALCHOICEHOSTING.COM
Name Server: DNS4.TOTALCHOICEHOSTING.COM
Name Server: NS8.another_host.COM
Name Server: NS9.another_host.COM
I don´t know if that will be a problem, but you might want remove the other host so you eliminate a potential problem.
i checked the file manager in the cpanel and the files did not upload to the www folder. i used filezilla which i never used before and it confused me. is there anyway to get the file manager reset back to how it was before i uploaded anything? it is a mess right now. :helpsmilie:
The easiest would probably be to ask the Techs to clean it for you.
And as a side note, the files should be placed in the public_html directory and not in www.
that's what i thought but when i looked at the cpanel of the other wordpress blog i have setup they were all in www, and that blog works fine.
I think it is a problem because if you go to the URL it is pointing back to the old site My linkwhich is hosted at Yahoo, the domain is also registered there. This is what Yahoo says on their Domain Management page...
"You can create up to four nameserver entries. Enter new nameserver addresses or edit the existing nameserver addresses below. Yahoo!'s name servers must be listed as Primary and Secondary in order for Yahoo! to host your domain services properly. If you add to or replace Yahoo!'s default nameservers, you will disrupt the services that Yahoo! provides."
Type: Nameserver Hostname:
1. Primary
2. Secondary
3. Additional
4. Additional
So I have my total choice nameservers listed as 3 & 4, and Yahoo's as primary and secondary. That doesn't seem right. :helpsmilie:
Thanks,
MB
