is it possible to use fancy indexing and make for instance
temp/j
accessible without password
but make the user unable to browse one directory up?
ie to just
temp
i've tried using web protect but its a hassle putting several passwords for several users and several directories.
any help appreciated!
Protection of dir is normally done from the htaccess which is done at the root. Why not use a subdomain. That way, the subdomain is seperate from the main root htaccess file.
What would be better is to leave off indexs and put a index.html into each folder. Then thoose folders without an index.html can be browsed whilst thoose with cant be
Jim
