jayson Posted September 1, 2008 Share Posted September 1, 2008 Can some one please look at my zen cart? When a person, registers, places an order or goes to the check out, they are sent to the page, but it is just blank, it is like the system times out on its self, I just need someone to try to register, here is the link to the site. http://www.blossomshopkinsfloral.com/store/ thanks Quote Link to comment Share on other sites More sharing options...
TCH-Thomas Posted September 1, 2008 Share Posted September 1, 2008 I tried adding a rose to my cart and got a blank page. Did not need to register to put that rose in the cart if it helps in the troubleshooting. Quote Link to comment Share on other sites More sharing options...
jayson Posted September 1, 2008 Author Share Posted September 1, 2008 any idea why it goes to a blank page? thanks for the input Quote Link to comment Share on other sites More sharing options...
TCH-Alex Posted September 2, 2008 Share Posted September 2, 2008 Try to use the following debug tool to find out the exact error h**p://www.zen-cart.com/index.php?main_page=product_contrib_info&products_id=860 Quote Link to comment Share on other sites More sharing options...
stevesh Posted September 2, 2008 Share Posted September 2, 2008 Most blank pages in Zencart are caused by unwanted spaces in PHP files. Did you edit the shopping cart page, or do you have mods installed which modify the shopping cart page? Quote Link to comment Share on other sites More sharing options...
jayson Posted September 3, 2008 Author Share Posted September 3, 2008 ok, I did the debug, and to be honest, do not under stand what it is telling me, is there some one here that can read the files and tell what they mean? thanks Quote Link to comment Share on other sites More sharing options...
stevesh Posted September 3, 2008 Share Posted September 3, 2008 Have you posted in the Zencart forums? A lot more specific expertise over there. Quote Link to comment Share on other sites More sharing options...
