TheMovieman Posted June 13, 2007 Posted June 13, 2007 I've tried to do several things in my forum (including upgrading to a new version), and it tells me it can't because the permissions are not set to writeable. I then tried to simply add in a couple smilies and I get this message: "The following smiley directories are not writable: default, classic" I logged into my SmartFTP and made sure everything was set, and it was... Anyone have experience with this? I'm using SMF, btw. Quote
TCH-Andy Posted June 13, 2007 Posted June 13, 2007 In sounds as if the permissions are not set to writable for world - please open a ticket and get us to check. Quote
TheMovieman Posted June 13, 2007 Author Posted June 13, 2007 (edited) For the "forum" folder, everything is set (group, world and all). Should I do this for the "public_html" as well? Edit: I went ahead and submitted a ticket just in case I missed something. Edited June 13, 2007 by TheMovieman Quote
TheMovieman Posted June 13, 2007 Author Posted June 13, 2007 OK, so that issue has been fixed but now when I try to upload a new smilie I get this error: 2: move_uploaded_file() [<a href='function.move-uploaded-file'>function.move-uploaded-file</a>]: open_basedir restriction in effect. File(/home/*removed*/public_html/forums/Smileys/default/Shrug4.gif) is not within the allowed path(s): (/home/*removed*/:/usr/local/sqmail/:/usr/lib/php:/usr/local/lib/php:/tmp) File: /home2/*removed*/public_html/forums/Sources/ManageSmileys.php Line: 345 Anyone encounter this? Quote
TCH-Bruce Posted June 13, 2007 Posted June 13, 2007 Please open a ticket with the help desk and have the techs take a look. Quote
TheMovieman Posted June 13, 2007 Author Posted June 13, 2007 One other thing, I'm trying to upgrade to the latest version but the last time I did this using Fantastico I got a fatal error and had to open a ticket to have them restore the backup. Just curious if I should try this again as I'm getting too far behind with the updates (I'm at 1.0.8 and the current one is 1.1.12, yet according to Fantastico, it's at 1.0.5). Quote
carbonize Posted June 13, 2007 Posted June 13, 2007 I assume he is referring to SMF since that is what he is using on his site. 1.0.8 is the last v1 release I believe with 1.1.2 being the current 1.1 release. My advice is to manually update. Quote
TCH-Bruce Posted June 13, 2007 Posted June 13, 2007 Can't you just upgrade from inside of SMF instead of using Fantastico to upgrade? I thought that was a feature of SMF. Quote
TheMovieman Posted June 13, 2007 Author Posted June 13, 2007 (edited) My advice is to manually update. See, I don't know how to manually upgrade. I've checked out SMF's forum but I'm just getting more and more confused... Edited June 13, 2007 by TheMovieman Quote
TheMovieman Posted June 13, 2007 Author Posted June 13, 2007 Oh, and I downloaded the zip file with the updated version, I just don't know how to do a proper backup of my current forum and then how to actually install this one... Quote
carbonize Posted June 13, 2007 Posted June 13, 2007 Auto update, if available, should be in Admin -> Packages. Back up files just by downloading them to your computer using FTP. Update by downloading update files (you might require full package going from 105 to 108) and simply replacing your existing files with the new ones. Quote
TCH-Thomas Posted June 13, 2007 Posted June 13, 2007 To download a database backup: Log in to cpanel Click "Backups" Scroll down to "Download a MySQL Database Backup" and click the forum database link. This will save a copy on your local computer. To download the forum files I would use the"home backup" option in the backup section. It will download more than you need, but on the other hand you will have a backup of all your files in your account. To upgrade SMF manually, please check their upgrade tutorial here. Quote
TheMovieman Posted June 13, 2007 Author Posted June 13, 2007 Thanks Thomas and carbonize. I'll give it a try in a little bit (did both backups as suggested). Quote
TheMovieman Posted June 13, 2007 Author Posted June 13, 2007 Well, I upgraded and it went pretty much OK, but now on the forum the "Last Post" image is missing from one of my themes. Now, this theme wasn't overwritten during the upgrade so I don't know what happened. Here's the page to see what I'm talking about: http://moviemansguide.com/forums/index.php/board,2.0.html Quote
TCH-Thomas Posted June 13, 2007 Posted June 13, 2007 Does the "last post" image show up if you are using any other theme? If yes, what happens if you reupload that image through either ftp or cpanel to the folder SMF is supposed to find it in? Apart from that, is the theme you are using compatible with the new version, ie the new version might be looking for something it can´t find due to a rewritten script and therefor looking for something it can not find and for that reason not showing the image? What I mean is that in the earlier version the code might have said "Show last-post-image.gif" and now it says "Show last-post-image.jpg" Quote
TheMovieman Posted June 14, 2007 Author Posted June 14, 2007 Does the "last post" image show up if you are using any other theme?If yes, what happens if you reupload that image through either ftp or cpanel to the folder SMF is supposed to find it in? Apart from that, is the theme you are using compatible with the new version, ie the new version might be looking for something it can´t find due to a rewritten script and therefor looking for something it can not find and for that reason not showing the image? What I mean is that in the earlier version the code might have said "Show last-post-image.gif" and now it says "Show last-post-image.jpg" Yeah, I guess the theme doesn't work for this current version since the image isn't in the zip file I have. I went ahead and just chose a new theme. Thanks for the help guys Quote
