Ok here is the problem, I had a problem getting into my cpanel, had the password reset, now I want to update coppermine, and this is the error I get. I do not understand the error:
Welcome to the Coppermine upgrade program
• • • ERROR • • •
The following errors were encountered and need to be corrected first:
Could not create a mySQL connection, please check the SQL values in include/config.inc.php
MySQL error was : Access denied for user 'jaysarah'@'localhost' (using password: YES)
Can I get a little help..
Thanks
Or should I open a trouble ticket...
• • • ERROR • • •
Thanks
Check the config file for coppermine (I believe it's in root dir of the installation). The config file will contain the SQL password.
In cPanel under MySQL icon:
- Delete the coppermine USER (I repeat, the USER - NOT THE DB).
- Re-create the user with the same credentials from the coppermine config.
- Add the user to the coppermine DB with all privs.
Edited by JRKy
ok did the mysql stuff,
logged into cpanel
clicked on mysql
entered user name of: jayjay (not true)
entered password : tchrocks (not true)
clicked on create user
it create a user name of jaysarah_jayjay (jaysarah is the DB name(why the XXXXXXX_XXXXX))
clicked on ad user to DB
went into the include/config.inc.php
changed dbusrname to jayjay (first)
changed DBpassword to tchrocks
then entered in www.XXXXXXXXXXXX.com/XXXXXX/update.php
ERROR:
• • • ERROR • • •
MySQL error was : Access denied for user 'jayjay'@'localhost' (using password: YES)
• • • ERROR • • •
ok did the mysql stuff a different way,
logged into cpanel
clicked on mysql
changed dbusrname to jaysarah_jayjay (second)
ERROR:
• • • ERROR • • •
MySQL error was : Access denied for user 'jaysarah_jayjay'@'localhost' (using password: YES)
• • • ERROR • • •
but I will keep plugging away....
Thanks
Edited by jayson
logged into cpanel
clicked on mysql
ERROR:
• • • ERROR • • •
• • • ERROR • • •
logged into cpanel
clicked on mysql
ERROR:
• • • ERROR • • •
• • • ERROR • • •
Thanks
Just create a user with the credentials you want. Add that user to the CP DB. Enter those credentials into the include/config.inc.php file (make sure you use the entire username - i.e. cpanel user name prepended to the db username). Then try your update.
