rdelp Posted October 28, 2006 Posted October 28, 2006 Greetings... I have been having problems with my site recently.. had phpnuke 7.3, it got hacked so I upgrade each upgrade to 7.9. in the process I deleted my /modules/forums/config.php since then I havent been able to get my forums or webmail to work.. Errors when accesing from web: http://www.livewxradar.com/modules.php?name=Forums From my admin screen: phpBB : Critical Error Error creating new session DEBUG MODE SQL Error : 1054 Unknown column 'session_admin' in 'field list' INSERT INTO nuke_bbsessions (session_id, session_user_id, session_start, session_time, session_ip, session_page, session_logged_in, session_admin) VALUES ('bc2673e7c76e668c9d2700eec47ceea5', '1', '1162069849', '1162069849', '443c00d4', '0', '0', '0') Line : 203 File : sessions.php I dont know much about SQL or Phpnuke for that matter.. from what I gather though reading the net. I have this for my forums config: ?php // phpBB 2.x auto-generated config file // Do not change anything in this file! $dbhost = "localhost"; $dbuname = "user name"; $dbpass = "the password"; $dbname = "db name"; $prefix = "nuke"; $user_prefix = "nuke"; $dbtype = "MySQL"; define('PHPBB_INSTALLED', true); ?> I have uname,dbpass and dbname filled out with what it supposed to be.. what else did I leave out?? Thanks! Rob Quote
TCH-Andy Posted October 28, 2006 Posted October 28, 2006 I'll let the nuke experts answer, but my guess is that you have a database from one version of nuke, and code from another. Quote
Tommy Posted October 29, 2006 Posted October 29, 2006 Did you run your upgrade file? I would be glad to take a look for you but will not be around till next tuesday.. If you want me to look at it PM me and I will tell you what I need to ck it out.. Quote
rdelp Posted October 30, 2006 Author Posted October 30, 2006 Did you run your upgrade file? I would be glad to take a look for you but will not be around till next tuesday.. If you want me to look at it PM me and I will tell you what I need to ck it out.. Hey Tommy, Thanks for the offer to help! Its great to know someone is willing to help. I had a friend of mine look at it today, he had to add a field to the db file and its working again. I guess the update I ran was not completed. All is well now. Thanks Rob D. Quote
