Paul_Ecuador Posted August 2, 2006 Posted August 2, 2006 (edited) Hi Forum Family: I have this site hoste by TCH: www.estrellasecuatorianas.com I have a JS problem in the backend. The full description of the problem is described here: Joomla Forum (I am PaulCoyote) I've tried all the sugestion of the partners... even reinstalled mambo but nothing seems to work. Could be a server issue? Can you pleeeeeeeeeeeeease give me some light? I have a couple of sites running Joomla 1.0.10 (www.ecosur.org www.martirena.com) and the backend editor works fine in them Regards Paul Edited August 2, 2006 by Paul_Ecuador Quote
TCH-JimE Posted August 2, 2006 Posted August 2, 2006 Paul, If I may, could you please PM me your administrator username/password for joomla and I will take a look. Btw are these all uploaded or have you tried the fanstico option and when you resintalled them, did you wipe the database too? JimE Quote
stevevan Posted August 2, 2006 Posted August 2, 2006 Reading the referenced Joomla! forum, I thought I'd add that I just installed a Joomla! website from Fantastico and all my settings were mos_*, not jos_*. And ver. 1.0.10 is the latest from the Joomla! developers. I haven't seen the problem you're describing and I'm running two sites in Joomla and one in Mambo (soon to be converted). Keep us posted on what you find out! Quote
Paul_Ecuador Posted August 2, 2006 Author Posted August 2, 2006 UPDATE (still not solved): - I've erased all the public_html directory - Installed via fantastico a fresh copy of Joomla - Tested the item editor, modified some items - Erased all the sample content - Erased all the categories and sections - Created a new section - Created a new category - Try to edit an item... AND STOP WORKING!!! the same javascript error I'm about to cry... Quote
stevevan Posted August 2, 2006 Posted August 2, 2006 I'll redo my test site once I get home tomorrow to play around and see if I get the same thing. Puzzling! Hopefully someone else will have a go and come up with the same problem. Quote
stevevan Posted August 2, 2006 Posted August 2, 2006 (edited) Started playing around just now (I was bored! ). Did a fresh install (database and all) of Joomla! 1.0.10 and haven't found any problems. The only thing I've done different than what you report in post #4 is that I haven't erased all of the content as I don't think that would have anything to do with why you get the javascript error. BTW...looking at your posts on the other site, the site info on mine says "$mosConfig_dbprefix = 'jos_';" , and yours says "$mosConfig_dbprefix = 'mos_';" . Possible conflict, I don't know. Have you tried a totally fresh install...database and all? Also, are your running Mambo or Joomla? Edited August 2, 2006 by stevevan Quote
Paul_Ecuador Posted August 3, 2006 Author Posted August 3, 2006 ALMOST SOLVED: - New fresh install (no using fantastico) www.estrellasecuatorianas.com on line - Started editing... everything works - Uploaded the template... keep working - Uploaded the images directory... STOP WORKING!!! I was using JCE EDITOR before the error... The editor of the webpage had uploaded a lot of pictures in the main directory of the images (/website/images/)... I delete all the images and the site works well I'm not sure wich image is the one who is causing the trouble. I upladed 2 directories inside the /stories and stop working again. I'm uploading the images again, one by one, and see what happen. The only isue that still is not solved is that in the full list of content items, I still get until the #20... and stops. But editor works (I'm using tynimce now) ABOUT THE JOS_ vs MOS_: I upgraded Mambo to joomla and kept the same database names, not a problem. The really great problem was the images directory. I'm now uploading one by one every image (about 800) and reinstalling every componente... boring... Regards Paul Quote
stevevan Posted August 4, 2006 Posted August 4, 2006 I'm now uploading one by one every image (about 800) and reinstalling every componente... boring... At least you'll eventually find the culprit...hopefully! Quote
TCH-JimE Posted August 7, 2006 Posted August 7, 2006 Very strange, but glad your getting there. with JCE, have you downloaded the image manager. With this you can set many options including where your pictures are saved etc JimE Quote
