Hey all,
I'm having a problem with the phpBB I have just installed. I cannot stay logged in and get to the administration panel. I have tried changing the cookie settings and have also modified the code to allow for switching IP addresses (I found this at the phpbb website). The script is still not working. Any suggestions?
Thanks,
rowanp.
  • 3 weeks later...
Does anyone have a solution? It would be greatly appreciated.
I think the problem is caused by my ISP using multiple IP clusters. For example, all the IPs that you see below are mine. phpBB views these as separate users when in fact it should see them as one and the same.
Guest Sun Jul 30, 2006 10:36 pm Sun Jul 30, 2006 10:36 pm Forum index 196.25.255.210
Guest Sun Jul 30, 2006 10:36 pm Sun Jul 30, 2006 10:36 pm Logging on 198.54.202.195
Guest Sun Jul 30, 2006 10:35 pm Sun Jul 30, 2006 10:35 pm Logging on 198.54.202.18
Guest Sun Jul 30, 2006 10:35 pm Sun Jul 30, 2006 10:35 pm Forum index 196.25.255.210
Guest Sun Jul 30, 2006 10:35 pm Sun Jul 30, 2006 10:35 pm Forum index 198.54.202.195
Guest Sun Jul 30, 2006 10:34 pm Sun Jul 30, 2006 10:34 pm Forum index 196.25.255.194
Guest Sun Jul 30, 2006 10:34 pm Sun Jul 30, 2006 10:34 pm Forum index 198.54.202.18
Edited by rowanp
