I´m install Joomla 1.0.9 and now necessary of this:
configuration.php Permission only reading
But, in Cpanel / file manager not have this file "configuration.php"
Have this configuration.php-dist
some suggestion ?
Thank´s
This is not really a problem. If that is the only error message you get, ignore it. At the final stage of the installation, you will be given the text that should be the content of your configuration.php file. Just paste this text into a file, rename it configuration.php, and then upload it to your Joomla directory.
Is it advisable to leave the config file on permanent writeable, or leave it as unwirteable and change it when you need to.
