LeeGoldsmith Posted June 1, 2006 Posted June 1, 2006 I installed Simple Machines with Fantastico and it created the MySQL database with user "mfxnjunn_smf1" but I have no idea what this users password is. Does anyone know what this would be. I need it to a conversion from IPB to SMF. Thanks for any help. Lee Quote
TCH-Bruce Posted June 1, 2006 Posted June 1, 2006 Didn't the installer ask you for a password? Normally they do. And it also usually emails you the information of the user/password. Quote
LeeGoldsmith Posted June 1, 2006 Author Posted June 1, 2006 Bruce That info is for the admin of the board, I think that the conversion program wants the MySQL user password. Is there any way to find out what the pssword is for the MySQL users in cPanel?? Lee Quote
TCH-Bruce Posted June 1, 2006 Posted June 1, 2006 You could use phpAdmin to change the password but I don't think you can see the password. Quote
TCH-Bruce Posted June 1, 2006 Posted June 1, 2006 You can also check any congfig files and see if it is there. Or you can add a new user with a new password and add it to the database. Quote
LeeGoldsmith Posted June 1, 2006 Author Posted June 1, 2006 Bruce Thanks for the ideas but I can't seem to see any way to set a new pasword in phpadmin, and I have a user that I know the password for and that does not work. I am going to SMF forum to see if someone there can help. Again thanks much for the help and if anyone else has an answer please pipe up. Thanks Lee Quote
TCH-JimE Posted June 1, 2006 Posted June 1, 2006 Hello Lee, If you access your cpanel, and then go to file manager. Use this to navigate to the folder containing SMF. I believe the file your looking for is settings.php Open this and scroll down to database info, this is where it shall be contained. JimE Quote
LeeGoldsmith Posted June 1, 2006 Author Posted June 1, 2006 JimE You are wonderful, that was what I needed - The conversion is done and I am a happy man. Thanks to Bruce as well. Lee Quote
