wvcrafted Posted May 12, 2006 Posted May 12, 2006 Hello- I know we are supposed to place the content in our Public_html folder, however when I connect to my site via FTP it always defaults to WWW. I have found myself uploading things into that directory several times. Is there a way to get it to open outside of the www directory? Like: one /home/c-panel name/ I would much rahter it open into my c-panel name directory. I have tried setting my WS_FTP up so it will and it doesn't seem to work. Also, what it the purpose of the WWW directory? Seems to be a duplicate of the Public_html folder. Is the contents of the Public folder automatically mapped into WWW? I have had Public_html or WWW on other hosts, but never both so just wondering. Thanks Quote
Kevan Posted May 12, 2006 Posted May 12, 2006 (edited) With WS_FTP you can set the Start In folder to whatever folder you want to start in. /home/yourcpanelname/ sounds like the setting you want. Make sure you check the box "save folder" Think of ./WWW as a map of ./public_html since it is the same logical folder. Since some scripts look for www instead of public_html my guess is this setting is for compatibility with those scripts. Edited May 12, 2006 by Kevan Quote
TCH-Don Posted May 12, 2006 Posted May 12, 2006 The www is a symbolic link to your public_html folder Most ftp programs have a place for a remote directory you normally put public_html there. If you leave it blank you should be taken to your root folder (/home/cpanelname/) Quote
Samrc Posted May 12, 2006 Posted May 12, 2006 In the version of WSFTP that I have, you must access the ADVANCED PROPERTIES to get to a tab that says STARTUP. Type in public_html in to the REMOTE SITE FOLDER field. Say ok, then be sure to SAVE your settings. From that point on, you will open within the public_html folder! You can see a screen print of the WSFTP program settings for one of my TCH websites on this page: h**p://www.samisite.com/publish/using_ftp.htm Note that I have used the /public_html and without the slash and both work. Quote
wvcrafted Posted May 12, 2006 Author Posted May 12, 2006 Thanks for the help everyone. I found the right settings and it opens up now where I want it. Quote
