I'm almost set up to use osc. I should be able to admin osc with an admin panel via domain.name/admin. When I do this I get the following message:
1046 - No database selected
select configuration_key as cfgKey, configuration_value as cfgValue from configuration
[TEP STOP]
Looks to me like I need to set a config file somewhere but don't know.
Thoughts?
Tx,
Brad Klein
Hang tight, I'm sure someone will be along that can assist you. But let me ask, did you create a database, create a user and add the user to the database?
Welcome to the forum, Brad :)
Did you install from your cpanel?
or download and install it your self,
if so the install instructions should have mentioned
creating a database, a database user , adding user to the database.
Hi Don,
Thanks for the response.
The db's were transferred to TotalChoice by the support crew. I came from another web host.
I can see the db's with phpmyadmin. I can also see that each user has been attached to each db using the cpanel/mysql tool. It tried two different logons/pw's. When I surf /admin, I still get the error.
Any other thoughts?
Hi Bruce,
The dbs were transfered from another web host by the Total Choice support folks. They look to be intact, and are OK when I repair them. Aside from that, I have two users attached to each db and still cannot logon with either logon.
Brad Klein
Not familiar with osc
but be sure the database config wherever it is is set up something like this.
host: localhost
database: yourCpanelName_databaseName
user: yourCpanelName_databaseUser
password: mypassword
* Note password is just as the password,
do not add the CpanelName to it.
Hi Bradkl, welcome to the forums!
I haven't used OSC for a while, but there should be two configure.php files. One in the includes folder, and one in the admin/includes folder. Make sure both of those configure.php files have the correct information, such as the database login information and the paths to the catalog and admin folders, etc.
Hope that helps!
