greenworld Posted February 25, 2006 Posted February 25, 2006 Hello; I need help here to finnish my installation of a autoresponder script, 1- does tch use Qmail or send mail? 2- part of the manual for bounce handling says: valiases (cPanel, etc) - Login via SSH or FTP and modify the file /etc/valiases/******, in it add the following line: bounce@yoursite.com: "|/home/username/public_html/cgi-bin/bounce.cgi" Once you discover how it's done on your server you can also setup signup and removal scripts with this method. I have no idea how to find what they say and edit it, I did looked in Cpanel, Ftp. thanks for any help. Quote
TCH-Bruce Posted February 25, 2006 Posted February 25, 2006 TCH uses sendmail and you do not have access to the /etc/valiases file. Quote
TCH-Andy Posted February 25, 2006 Posted February 25, 2006 As Bruce says, you don't have direct access to the file. You can add "|/home/username/public_html/cgi-bin/bounce.cgi" as a forward for bounce@yoursite.com in your cpanel though, which will add it to the etc/valiases file Quote
