Oso_Grizzly Posted January 5, 2006 Posted January 5, 2006 I have this very unusual problem. I am unable to navigate this site using Internet Explorer. I can not pass this page http://montufarcpa.com/Espanol/Intro_es.html. If you hover over the buttons, there appear to be no hyperlinks attach to them. I have tested it in other computers and the same problems appears But if I use Netscape, there is no problem at all, all links show up and can navigate all pages of the site. Is this a problem with the my Internet Explorer version? Some type of security or configuration problem? I am useing IE 6.0.28 Thanks for your assistance Osog Quote
Oso_Grizzly Posted January 5, 2006 Author Posted January 5, 2006 Is there a way to get 6.0.29 with out updating to Service Pack 2 ? In theory there should be no problem with the version I am using. What do you think might be the problem ? Perhaps something with the Java applet ? Another thing I found out. If you access directly any of the other pages of the site, you can navigate without problems. The hyperlinks work fine back and forth . Those pages also contain Java applets. It appears that the problem is with one page only. I have reloaded the entire site several times and the problem persists. Can it be that there is something wrong in the configuration (parameters) of this single page ? I have ran out of theories or solutions. Thanks for taking the time in helping me out Osog Quote
TCH-Andy Posted January 5, 2006 Posted January 5, 2006 This page, and many of the others are not valid HTML, hence they are interpreted differently by different browsers. I'd suggest looking at http://validator.w3.org/detailed.html and modifying the code so that it validates first. Then it should work. Quote
