i own fp97, 98 2000 and 2002 all were upgrades i like working in 2000 but had 2002 installed, so i removed 2002 and wanted to start the install process over to get back to 2000, but when i try to install 97 it now says 3.0 cant be installed over 4.0.....so i have some files to remove, but where??
It's been a while since I tried anything like but you shouldn't have to start with with the oldest one.
It should allow you to start with 2000, then at some point it will ask you to insert the CD of a previous version of FrontPage.
welcome to the forum <_<
I'd use one of the many programs for clearing your registry of any rubbish (there are a number of good ones about, just google for "register cleaner utility") Alternatively - just use regedit, and search.
Remember to take a backup first of course :)
Welcome to the forums! FWIW...I have FP 98 and 2000. Whenever I reinstalled it, Micro$oft MADE me install 98 first. That was part of the reason I pushed myself to learn HTML and wean away from Micro$oft. IMHO...Frontpage is a good tool to use when you are first starting out. It helps you learn HTML. But the more you play, the more you'll want to leave it in the dust.
