I'm trying to get an advanced guestbook up and running. Right now, I'm having problems with the installation. I'm doing it through my CPanel:
It all comes through okay, saying it was created, but when I go to login, and do some editting, I get this:
Warning: main(./extension.inc): failed to open stream: No such file or directory in /home/dkhnxsfo/public_html/pddollsbook/index.php on line 25
Warning: main(): Failed opening './extension.inc' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/dkhnxsfo/public_html/pddollsbook/index.php on line 25
Warning: main(./common.): failed to open stream: No such file or directory in /home/dkhnxsfo/public_html/pddollsbook/index.php on line 26
Warning: main(): Failed opening './common.' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/dkhnxsfo/public_html/pddollsbook/index.php on line 26
Fatal error: Call to undefined function: session_pagestart() in /home/dkhnxsfo/public_html/pddollsbook/index.php on line 31
I swear, I had one when I first got my domain up and running, and it worked fine (deleted it because I'd forgotten the password and didn't want it at that time).
So, any ideas on how to fix?
Did you use the same name for both guestbooks? If so, you might try to create a second one with a diffrent name, and see how that one works. Cpanel sometimes doesn't remember to clean up after it's own messes, and leaves parts of files here and there, or forgets to replace something somewhere else. Check that out. If it happens every time you create a new and diffrent one, then I think we might have to go back to the drawing board.
Trying it now ....
Nope, I get the same thing :(
I figured out what the problem is, but no clue how to fix it:
The index page is the same, basically, as that of a PHPBB forum. That's not what I was wanting.:
><?php
*                                index.php
*   begin                : Saturday, Feb 13, 2001
*   copyright            : (C) 2001 The phpBB Group
*   email                : support@phpbb.com
*   $Id: index.php,v 1.99.2.3 2004/07/11 16:46:15 acydburn Exp $
*   This program is free software; you can redistribute it and/or modify
*   it under the terms of the GNU General Public License as published by
*   the Free Software Foundation; either version 2 of the License, or
*   (at your option) any later version.
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
// Start session management
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
// End session management
$viewcat = ( !empty($HTTP_GET_VARS[POST_CAT_URL]) ) ? $HTTP_GET_VARS[POST_CAT_URL] : -1;
if( isset($HTTP_GET_VARS['mark']) || isset($HTTP_POST_VARS['mark']) )
$mark_read = ( isset($HTTP_POST_VARS['mark']) ) ? $HTTP_POST_VARS['mark'] : $HTTP_GET_VARS['mark'];
else
$mark_read = '';
// Handle marking posts
if( $mark_read == 'forums' )
if( $userdata['session_logged_in'] )
 setcookie($board_config['cookie_name'] . '_f_all', time(), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
$template->assign_vars(array(
 "META" => '<meta http-equiv="refresh" content="3;url='  .append_sid("index.$phpEx") . '">')
$message = $lang['Forums_marked_read'] . '<br /><br />' . sprintf($lang['Click_return_index'], '<a href="' . append_sid("index.$phpEx") . '">', '</a> ');
message_die(GENERAL_MESSAGE, $message);
// End handle marking posts
$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_t"]) : array();
$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . "_f"]) : array();
// If you don't use these stats on your index you may want to consider
// removing them
$total_posts = get_db_stat('postcount');
$total_users = get_db_stat('usercount');
$newest_userdata = get_db_stat('newestuser');
$newest_user = $newest_userdata['username'];
$newest_uid = $newest_userdata['user_id'];
if( $total_posts == 0 )
$l_total_post_s = $lang['Posted_articles_zero_total'];
else if( $total_posts == 1 )
$l_total_post_s = $lang['Posted_article_total'];
else
$l_total_post_s = $lang['Posted_articles_total'];
if( $total_users == 0 )
$l_total_user_s = $lang['Registered_users_zero_total'];
else if( $total_users == 1 )
$l_total_user_s = $lang['Registered_user_total'];
else
$l_total_user_s = $lang['Registered_users_total'];
// Start page proper
$sql = "SELECT c.cat_id, c.cat_title, c.cat_order
FROM " . CATEGORIES_TABLE . " c
ORDER BY c.cat_order";
if( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not query categories list', '', __LINE__, __FILE__, $sql);
$category_rows = array();
while( $category_rows[] = $db->sql_fetchrow($result) );
$db->sql_freeresult($result);
if( ( $total_categories = count($category_rows) ) )
// Define appropriate SQL
switch(SQL_LAYER)
 case 'postgresql':
	 $sql = "SELECT f.*, p.post_time, p.post_username, u.username, u.user_id
   FROM " . FORUMS_TABLE . " f, " . POSTS_TABLE . " p, " . USERS_TABLE . " u
   WHERE p.post_id = f.forum_last_post_id
  	 AND u.user_id = p.poster_id
  	 UNION (
     SELECT f.*, NULL, NULL, NULL, NULL
     WHERE NOT EXISTS (
    	 SELECT p.post_time
    	 FROM " . POSTS_TABLE . " p
  	 ORDER BY cat_id, forum_order";
	 break;
 case 'oracle':
   WHERE p.post_id = f.forum_last_post_id(+)
  	 AND u.user_id = p.poster_id(+)
   ORDER BY f.cat_id, f.forum_order";
	 break;
 default:
   FROM (( " . FORUMS_TABLE . " f
   LEFT JOIN " . POSTS_TABLE . " p ON p.post_id = f.forum_last_post_id )
   LEFT JOIN " . USERS_TABLE . " u ON u.user_id = p.poster_id )
	 break;
if ( !($result = $db->sql_query($sql)) )
 message_die(GENERAL_ERROR, 'Could not query forums information', '', __LINE__, __FILE__, $sql);
$forum_data = array();
while( $row = $db->sql_fetchrow($result) )
 $forum_data[] = $row;
if ( !($total_forums = count($forum_data)) )
 message_die(GENERAL_MESSAGE, $lang['No_forums']);
// Obtain a list of topic ids which contain
// posts made since user last visited
if ( $userdata['session_logged_in'] )
 $sql = "SELECT t.forum_id, t.topic_id, p.post_time
	 FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
	 WHERE p.post_id = t.topic_last_post_id
   AND p.post_time > " . $userdata['user_lastvisit'] . "
   AND t.topic_moved_id = 0";
	 message_die(GENERAL_ERROR, 'Could not query new topic information', '', __LINE__, __FILE__, $sql);
 $new_topic_data = array();
 while( $topic_data = $db->sql_fetchrow($result) )
	 $new_topic_data[$topic_data['forum_id']][$topic_data['topic_id']] = $topic_data['post_time'];
// Obtain list of moderators of each forum
// First users, then groups ... broken into two queries
$sql = "SELECT aa.forum_id, u.user_id, u.username
 FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
 WHERE aa.auth_mod = " . TRUE . "
	 AND g.group_single_user = 1
	 AND ug.group_id = aa.group_id
	 AND g.group_id = aa.group_id
	 AND u.user_id = ug.user_id
 GROUP BY u.user_id, u.username, aa.forum_id
 ORDER BY aa.forum_id, u.user_id";
 message_die(GENERAL_ERROR, 'Could not query forum moderator information', '', __LINE__, __FILE__, $sql);
$forum_moderators = array();
 $forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=" . $row['user_id']) . '">' . $row['username'] . '</a>';
$sql = "SELECT aa.forum_id, g.group_id, g.group_name
	 AND g.group_single_user = 0
	 AND g.group_type <> " . GROUP_HIDDEN . "
 GROUP BY g.group_id, g.group_name, aa.forum_id
 ORDER BY aa.forum_id, g.group_id";
 $forum_moderators[$row['forum_id']][] = '<a href="' . append_sid("groupcp.$phpEx?" . POST_GROUPS_URL . "=" . $row['group_id']) . '">' . $row['group_name'] . '</a>';
// Find which forums are visible for this user
$is_auth_ary = array();
$is_auth_ary = auth(AUTH_VIEW, AUTH_LIST_ALL, $userdata, $forum_data);
// Start output of page
define('SHOW_ONLINE', true);
$page_title = $lang['Index'];
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
$template->set_filenames(array(
 'body' => 'index_body.tpl')
 'TOTAL_POSTS' => sprintf($l_total_post_s, $total_posts),
 'TOTAL_USERS' => sprintf($l_total_user_s, $total_users),
 'NEWEST_USER' => sprintf($lang['Newest_user'], '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$newest_uid") . '">', $newest_user, '</a>'),
 'FORUM_IMG' => $images['forum'],
 'FORUM_NEW_IMG' => $images['forum_new'],
 'FORUM_LOCKED_IMG' => $images['forum_locked'],
 'L_FORUM' => $lang['Forum'],
 'L_TOPICS' => $lang['Topics'],
 'L_REPLIES' => $lang['Replies'],
 'L_VIEWS' => $lang['Views'],
 'L_POSTS' => $lang['Posts'],
 'L_LASTPOST' => $lang['Last_Post'],
 'L_NO_NEW_POSTS' => $lang['No_new_posts'],
 'L_NEW_POSTS' => $lang['New_posts'],
 'L_NO_NEW_POSTS_LOCKED' => $lang['No_new_posts_locked'],
 'L_NEW_POSTS_LOCKED' => $lang['New_posts_locked'],
 'L_ONLINE_EXPLAIN' => $lang['Online_explain'],
 'L_MODERATOR' => $lang['Moderators'],
 'L_FORUM_LOCKED' => $lang['Forum_is_locked'],
 'L_MARK_FORUMS_READ' => $lang['Mark_all_forums'],
 'U_MARK_READ' => append_sid("index.$phpEx?mark=forums"))
// Okay, let's build the index
for($i = 0; $i < $total_categories; $i++)
 $cat_id = $category_rows[$i]['cat_id'];
 // Should we display this category/forum set?
 $display_forums = false;
 for($j = 0; $j < $total_forums; $j++)
	 if ( $is_auth_ary[$forum_data[$j]['forum_id']]['auth_view'] && $forum_data[$j]['cat_id'] == $cat_id )
   $display_forums = true;
 // Yes, we should, so first dump out the category
 // title, then, if appropriate the forum list
 if ( $display_forums )
	 $template->assign_block_vars('catrow', array(
   'CAT_ID' => $cat_id,
   'CAT_DESC' => $category_rows[$i]['cat_title'],
   'U_VIEWCAT' => append_sid("index.$phpEx?" . POST_CAT_URL . "=$cat_id"))
	 if ( $viewcat == $cat_id || $viewcat == -1 )
  	 if ( $forum_data[$j]['cat_id'] == $cat_id )
     $forum_id = $forum_data[$j]['forum_id'];
     if ( $is_auth_ary[$forum_id]['auth_view'] )
    	 if ( $forum_data[$j]['forum_status'] == FORUM_LOCKED )
       $folder_image = $images['forum_locked'];
       $folder_alt = $lang['Forum_locked'];
    	 else
       $unread_topics = false;
      	 if ( !empty($new_topic_data[$forum_id]) )
         $forum_last_post_time = 0;
         while( list($check_topic_id, $check_post_time) = @each($new_topic_data[$forum_id]) )
        	 if ( empty($tracking_topics[$check_topic_id]) )
           $unread_topics = true;
           $forum_last_post_time = max($check_post_time, $forum_last_post_time);
        	 else
           if ( $tracking_topics[$check_topic_id] < $check_post_time )
         if ( !empty($tracking_forums[$forum_id]) )
        	 if ( $tracking_forums[$forum_id] > $forum_last_post_time )
         if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all']) )
        	 if ( $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f_all'] > $forum_last_post_time )
       $folder_image = ( $unread_topics ) ? $images['forum_new'] : $images['forum'];
       $folder_alt = ( $unread_topics ) ? $lang['New_posts'] : $lang['No_new_posts'];
    	 $posts = $forum_data[$j]['forum_posts'];
    	 $topics = $forum_data[$j]['forum_topics'];
    	 if ( $forum_data[$j]['forum_last_post_id'] )
       $last_post_time = create_date($board_config['default_dateformat'], $forum_data[$j]['post_time'], $board_config['board_timezone']);
       $last_post = $last_post_time . '<br />';
       $last_post .= ( $forum_data[$j]['user_id'] == ANONYMOUS ) ? ( ($forum_data[$j]['post_username'] != '' ) ? $forum_data[$j]['post_username'] . ' ' : $lang['Guest'] . ' ' ) : '<a href="' . append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . '='  . $forum_data[$j]['user_id']) . '">' . $forum_data[$j]['username'] . '</a> ';
       $last_post .= '<a href="' . append_sid("viewtopic.$phpEx?"  . POST_POST_URL . '=' . $forum_data[$j]['forum_last_post_id']) . '#' . $forum_data[$j]['forum_last_post_id'] . '"><img src="' . $images['icon_latest_reply'] . '" border="0" alt="' . $lang['View_latest_post'] . '" title="' . $lang['View_latest_post'] . '" /></a>';
    	 else
       $last_post = $lang['No_Posts'];
    	 if ( count($forum_moderators[$forum_id]) > 0 )
       $l_moderators = ( count($forum_moderators[$forum_id]) == 1 ) ? $lang['Moderator'] : $lang['Moderators'];
       $moderator_list = implode(', ', $forum_moderators[$forum_id]);
    	 else
       $l_moderators = ' ';
       $moderator_list = ' ';
    	 $row_color = ( !($i % 2) ) ? $theme['td_color1'] : $theme['td_color2'];
    	 $row_class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
    	 $template->assign_block_vars('catrow.forumrow',	array(
       'ROW_COLOR' => '#' . $row_color,
       'ROW_CLASS' => $row_class,
       'FORUM_FOLDER_IMG' => $folder_image,
       'FORUM_NAME' => $forum_data[$j]['forum_name'],
       'FORUM_DESC' => $forum_data[$j]['forum_desc'],
       'POSTS' => $forum_data[$j]['forum_posts'],
       'TOPICS' => $forum_data[$j]['forum_topics'],
       'LAST_POST' => $last_post,
       'MODERATORS' => $moderator_list,
       'L_MODERATOR' => $l_moderators,
       'L_FORUM_FOLDER_ALT' => $folder_alt,
       'U_VIEWFORUM' => append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"))
} // for ... categories
}// if ... total_categories
else
// Generate the page
$template->pparse('body');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
  • 1 month later...
