Okay, sorry, I'm a noobie so if this isn't the right forum i'm super sorry. But could someone give me a step-by-step on how to use imagemagick with 4images? I am SSSSOO confused.
Welcome to the forum spongie93 :clapping:
I am not familiar with that script,
but some gallery scripts have a problem recognizing imagemagick
Like coppermine, where you have to select GD instead
and then after the install you go back
and change the config to use imagemagick .
Isn't 4images the one that stole nearly all of it's code from phpBB?
As for the problem I'd follow Don's sugestion of selecting GD on install then if it installs ok try switching to Imagemagick. Is this a problem with the server though or just a problem with the script? Does the script have support for Imagemagick?
