rappeto Posted August 11, 2005 Posted August 11, 2005 Hello, I would like to make some changes to my advanced guestbook but it won't let me until I set the correct permissions. I've looked on several other forums to get the answer but all I see is conflicting information about what numbers to set and in what location to set them. The changes I want to make are simple I think. I just want to add a link back to my page from the guestbook and stuff like that. Can someone here please help with the permission settings? Thanks. Quote
abinidi Posted August 11, 2005 Posted August 11, 2005 Well, I don't know the answer to your question; I don't use any guestbook software at all. But I thought I'd say hello and welcome to the forums. So, Hello. Welcome to the forums!! Hopefully somebody will come along in a little while, and will be able to help you out with your question. Quote
TCH-Bruce Posted August 11, 2005 Posted August 11, 2005 Sorry, I've never used Advanced Guestbook either. Welcome to the forums. I'm sure one of our family members that uses it will be along to offer assistance. Quote
TCH-Don Posted August 12, 2005 Posted August 12, 2005 Welcome to the forum, rappeto I would donwload the file you are trying to change and edit it on your computer then upload the changed file back. this way you do not have to worry about permissions. Quote
carbonize Posted August 12, 2005 Posted August 12, 2005 Bet when you saw the five emails you would of received saying you had received a reply you thought one of them may of been the answer. Instead the sixth reply is the answer. Go figure. Anyway to use the edit templates section of the Admin you need to CHMOD the template files to 777. Personally I don't recommend this and suggest that you download the files to your computer first and edit them on there before uploading them again. Quote
